8b10b-Encoding bei dem nur 80% der brutto Datenrate nutzbar sind, sagt Dir auch überhaupt nichts.Im Übrigen arbeitet SATA II mit 3Gbit/s, somit sind (zumindest theoretisch) auch höhere Datenraten möglich.
Oct 25 16:07:48 server2 smartd[3871]: Device: /dev/sda, 4232 Offline uncorrectable sectors
Oct 25 16:07:48 server2 smartd[3871]: Device: /dev/sda, SMART Usage Attribute: 9 Power_On_Hours changed from 23 to 24
Oct 25 16:07:48 server2 smartd[3871]: Device: /dev/sda, Failed SMART usage Attribute: 195 Hardware_ECC_Recovered.
Oct 25 16:07:48 server2 smartd[3871]: Device: /dev/sda, Failed SMART usage Attribute: 196 Reallocated_Event_Count.
Oct 25 16:07:48 server2 smartd[3871]: Device: /dev/sda, Failed SMART usage Attribute: 197 Current_Pending_Sector.
Oct 25 16:07:48 server2 smartd[3871]: Device: /dev/sda, SMART Usage Attribute: 199 UDMA_CRC_Error_Count changed from 29 to 69
Oct 25 16:07:48 server2 smartd[3871]: Device: /dev/sda, SMART Usage Attribute: 201 Soft_Read_Error_Rate changed from 162 to 47
Oct 25 16:07:48 server2 smartd[3871]: Device: /dev/sda, Failed SMART usage Attribute: 204 Shock_Count_Write_Opern.
Oct 25 16:07:48 server2 smartd[3871]: Device: /dev/sda, Failed SMART usage Attribute: 211 Unknown_Attribute.
Oct 25 16:07:48 server2 smartd[3871]: Device: /dev/sdb, 1962 Offline uncorrectable sectors
Oct 25 16:07:48 server2 smartd[3871]: Device: /dev/sdb, SMART Usage Attribute: 9 Power_On_Hours changed from 23 to 24
Oct 25 16:07:48 server2 smartd[3871]: Device: /dev/sdb, Failed SMART usage Attribute: 195 Hardware_ECC_Recovered.
Oct 25 16:07:48 server2 smartd[3871]: Device: /dev/sdb, Failed SMART usage Attribute: 196 Reallocated_Event_Count.
Oct 25 16:07:48 server2 smartd[3871]: Device: /dev/sdb, Failed SMART usage Attribute: 197 Current_Pending_Sector.
Oct 25 16:07:48 server2 smartd[3871]: Device: /dev/sdb, SMART Usage Attribute: 199 UDMA_CRC_Error_Count changed from 142 to 182
Oct 25 16:07:48 server2 smartd[3871]: Device: /dev/sdb, SMART Usage Attribute: 201 Soft_Read_Error_Rate changed from 53 to 193
Oct 25 16:07:48 server2 smartd[3871]: Device: /dev/sdb, Failed SMART usage Attribute: 204 Shock_Count_Write_Opern.
Oct 25 16:07:48 server2 smartd[3871]: Device: /dev/sdb, Failed SMART usage Attribute: 211 Unknown_Attribute.
Oct 25 16:37:48 server2 smartd[3871]: Device: /dev/sda, 4232 Offline uncorrectable sectors
Oct 25 16:37:48 server2 smartd[3871]: Device: /dev/sda, Failed SMART usage Attribute: 195 Hardware_ECC_Recovered.
Oct 25 16:37:48 server2 smartd[3871]: Device: /dev/sda, Failed SMART usage Attribute: 196 Reallocated_Event_Count.
Oct 25 16:37:48 server2 smartd[3871]: Device: /dev/sda, Failed SMART usage Attribute: 197 Current_Pending_Sector.
Oct 25 16:37:48 server2 smartd[3871]: Device: /dev/sda, SMART Usage Attribute: 201 Soft_Read_Error_Rate changed from 47 to 196
Oct 25 16:37:48 server2 smartd[3871]: Device: /dev/sda, Failed SMART usage Attribute: 204 Shock_Count_Write_Opern.
Oct 25 16:37:48 server2 smartd[3871]: Device: /dev/sda, Failed SMART usage Attribute: 211 Unknown_Attribute.
Oct 25 16:37:48 server2 smartd[3871]: Device: /dev/sdb, 1962 Offline uncorrectable sectors
Oct 25 16:37:48 server2 smartd[3871]: Device: /dev/sdb, Failed SMART usage Attribute: 195 Hardware_ECC_Recovered.
Oct 25 16:37:48 server2 smartd[3871]: Device: /dev/sdb, Failed SMART usage Attribute: 196 Reallocated_Event_Count.
Oct 25 16:37:48 server2 smartd[3871]: Device: /dev/sdb, Failed SMART usage Attribute: 197 Current_Pending_Sector.
Oct 25 16:37:48 server2 smartd[3871]: Device: /dev/sdb, SMART Usage Attribute: 201 Soft_Read_Error_Rate changed from 193 to 88
Oct 25 16:37:48 server2 smartd[3871]: Device: /dev/sdb, Failed SMART usage Attribute: 204 Shock_Count_Write_Opern.
Oct 25 16:37:48 server2 smartd[3871]: Device: /dev/sdb, Failed SMART usage Attribute: 211 Unknown_Attribute.
Oct 25 17:07:48 server2 smartd[3871]: Device: /dev/sda, 4232 Offline uncorrectable sectors
Oct 25 17:07:48 server2 smartd[3871]: Device: /dev/sda, SMART Usage Attribute: 9 Power_On_Hours changed from 24 to 25
Oct 25 17:07:48 server2 smartd[3871]: Device: /dev/sda, Failed SMART usage Attribute: 195 Hardware_ECC_Recovered.
Oct 25 17:07:48 server2 smartd[3871]: Device: /dev/sda, Failed SMART usage Attribute: 196 Reallocated_Event_Count.
Oct 25 17:07:48 server2 smartd[3871]: Device: /dev/sda, Failed SMART usage Attribute: 197 Current_Pending_Sector.
Oct 25 17:07:48 server2 smartd[3871]: Device: /dev/sda, SMART Usage Attribute: 199 UDMA_CRC_Error_Count changed from 69 to 125
Oct 25 17:07:48 server2 smartd[3871]: Device: /dev/sda, SMART Usage Attribute: 201 Soft_Read_Error_Rate changed from 196 to 49
Oct 25 17:07:48 server2 smartd[3871]: Device: /dev/sda, Failed SMART usage Attribute: 204 Shock_Count_Write_Opern.
Oct 25 17:07:48 server2 smartd[3871]: Device: /dev/sda, SMART Usage Attribute: 208 Spin_Buzz changed from 5 to 6
Oct 25 17:07:48 server2 smartd[3871]: Device: /dev/sda, Failed SMART usage Attribute: 211 Unknown_Attribute.
Oct 25 17:07:48 server2 smartd[3871]: Device: /dev/sdb, 1962 Offline uncorrectable sectors
Oct 25 17:07:48 server2 smartd[3871]: Device: /dev/sdb, SMART Usage Attribute: 9 Power_On_Hours changed from 24 to 25
Oct 25 17:07:48 server2 smartd[3871]: Device: /dev/sdb, Failed SMART usage Attribute: 195 Hardware_ECC_Recovered.
Oct 25 17:07:48 server2 smartd[3871]: Device: /dev/sdb, Failed SMART usage Attribute: 196 Reallocated_Event_Count.
Oct 25 17:07:48 server2 smartd[3871]: Device: /dev/sdb, Failed SMART usage Attribute: 197 Current_Pending_Sector.
Oct 25 17:07:48 server2 smartd[3871]: Device: /dev/sdb, SMART Usage Attribute: 199 UDMA_CRC_Error_Count changed from 182 to 238
Oct 25 17:07:48 server2 smartd[3871]: Device: /dev/sdb, SMART Usage Attribute: 201 Soft_Read_Error_Rate changed from 88 to 197
Oct 25 17:07:48 server2 smartd[3871]: Device: /dev/sdb, Failed SMART usage Attribute: 204 Shock_Count_Write_Opern.
Natürlich 43nm. Bei den ganzen Größen und Wechseln bei Toshiba, Samsung und Intel bin ich wohl beim Schreiben etwas durcheinander gekommen.
Indilinx wird wohl noch dieses Jahr anfangen 40nm Flash von Samsung einzusetzen. Mit den 32nm-Chips rechne ich bei Samsung-SSDs frühestens in Q4, bei Indilinx erst in 2010.
Die IM Flash laufen mit dem aktuellen Barefoot nur in 50nm. bei 34NM flash muss derzeit runtergetaktet werden damit die ordentlich laufen.
Mit dem BArefoot ECO soll dann auch der 34nm IM flash normal laufen.
AFAIK setzt OCZ den runtergetakteten bei den neuen Solid 2 ein.
FW 1.41 entspricht FW 1819 bei Supertalent. In dem FW Changelog sind viele S.M.A.R.T. Bug fixes enthalten:habe seit gestern in meinem Server zwei 32GB OCZ Vertex drin. Firmware ist noch die 1.3.
sda und sdb sind die beiden Vertex...
Betriebssystem ist Debian Lenny, Kernel 2.6.26-2-xen-amd64.
SATA ist auf AHCI eingestellt, Board ist ein Asus Rampage II Gene mit 3x2GB RAM.
An SATA-Port 3-6 hängen 4x1TB HD103SJ.
du hast wahrscheinlich die Intel Matrix oder AMD Treiber installiert die den Trim befehl nicht durch lassen, da kann dann OCZ auch nix dafür.
Schmeiß die treiber runter und nutze die standart Microsoft treiber die dir windows automatisch installiert, dann klappt auch trim.
Oder stell auf IDE um dann funktionierts so oder so![]()
dein smart-daemon kann mit einer SSD einfach noch nichts anfangen.
abschalten und das problem ist gelöst.
http://www.supertalent.com/support/download/UltraDrive_Firmware_Release_Notes_v1819.pdf
Zumindest sollte Dein Dein S.M.A.R.T. Errorlog reduzieren.Klingt gut, weißt du ob das nur kosmetische Bug Fixes sind oder könnten die sogar was am "einfrieren" ändern?
Oder warte noch 2 Jahre dann hat das Intel in seine Matrixtreiber auch integriert, nachdem einige Petitionen gelaufen sind.![]()
