BIOS
Zum Testzeitpunkt bot uns ASUS die BIOS-Version 1067 mit AGESA 1.2.0.3e an, die wir ohne Probleme mittels Instant-Flash aufspielen konnten. Seit dem Release des ROG Strix B850-I Gaming WiFi hat ASUS im BIOS-Segment folgende Änderungen vorgenommen:
BIOS 1067:
- Improve SSD compatibility
BIOS 1063:
- Updated AGESA to ComboAM5 PI 1.2.0.3e for upcoming CPU compatibility
- Enhanced system performance and stability
- Important: This update is irreversible. Rolling back to older BIOS versions is not supported
BIOS 1028:
- This update enhances compatibility with high-capacity memory modules and improves overall system performance
BIOS 1022:
- Enhanced system performance with support for 9950X3D and 9900X3D processors
- Included AI Cache Boost to enhance performance and compute power when using AI-based tools
BIOS 1006:
- Updated AGESA to PI 1.2.0.3a Patch A. Please update the chipset driver to version 7.01.08.129 or newer to enhance gaming performance in select games
- Improved system performance and resolved the PeCoffLoader memory overflow issue for enhanced security
- This BIOS enhances system performance and improves high-capacity memory compatibility. This includes support for 2*DIMM memory configurations, achieving speeds up to 6800MT/s with AEMP enabled
BIOS 1001 (Beta):
- Updated AGESA to ComboAM5 PI 1.2.0.3. Please also update the chipset driver to version 7.01.08.129 or newer to enhance gaming performance for select games
- Improved system performance and fixed the PeCoffLoader memory overflow issue for security
BIOS 0825:
- Updated AMD AGESA to version 1.2.0.2b
- Fixed a few fan-related bugs and improved overall system performance
BIOS 0817:
- Include Turbo Game Mode: Enhance performance in certain games
- Update AGESA Version to Combo AM5 PI 1.2.0.2a: Enhance compatibility and performance
Generell werden dunkle Farben auf den Monitor gezaubert, passend zum ROG-Mainboard. Dabei werden die einzelnen Punkte gelb hervorgehoben und die restlichen Werte in weißer Schrift dargestellt. Oben links angefangen, sind an dieser Stelle das aktuelle Datum und auch die Uhrzeit einsehbar. Rechts daneben kann auch die generelle UEFI-Sprache geändert werden. Mit dabei ist der "AI OC Guide", der eine Art Overclocking-Assistent ist und Neueinsteigern das Overclocking einfacher machen soll. Eingefleischte Overclocker werden von dieser Funktion in der Regel die Finger lassen und stattdessen sämtliche Einstellungen manuell festlegen. Dennoch ist es schön zu sehen, dass Einsteiger nicht im Regen stehen gelassen werden.
In der nächsten Zeile werden die üblichen Vorabinformationen wie das Mainboardmodell inkl. BIOS-Version, die aktuell installierte CPU inkl. Taktfrequenz sowie die Arbeitsspeicher-Kapazität angezeigt. Weiter rechts sind dann auch gleich die CPU- und Mainboard-Temperatur zusehen, zusätzlich auch die CPU-Spannung. Eine Etage tiefer teilt auf der linken Seite ein ergänzender RAM-Status mit, in welchen Slots aktuell welche Module mit welcher Kapazität und der aktuell anliegenden Taktung installiert sind. Zudem kann auf Wunsch auch gleich das EXPO-Feature (Extended Profile for Overclocking) ausgewählt werden, sofern vorhanden. Wer sich für die derzeit angekoppelten Storage-Gerätschaften interessiert, erhält diese Infos direkt rechts daneben. Hinzu kommen dann wiederum unten noch die Lüftergeschwindigkeiten, die sich mit der Funktion "QFan Control" auch gleich individuell festlegen lassen.
Am rechten Rand des Bildschirms kann vom Anwender das grundlegende Funktionsschema ausgewählt werden. Standardmäßig ist der normale Modus aktiviert. Es lassen sich jedoch auch "ASUS Optimal" und der Modus "Power Saving" aktivieren. Während beim "ASUS Optimal"-Modus das System auf gesteigerte Performance ausgelegt ist, lässt sich das Setup mit dem "Power Saving"-Modus effizienter betreiben. Darunter kann die Boot-Reihenfolge mit Leichtigkeit abgeändert werden. Entweder per Klick auf "Advanced Mode" oder mit einem Tastendruck auf "F7" gelangen wir in die erweiterte Ansicht, die wir uns nun anschauen werden.
Advanced-Mode: Optisch genau wie der EZ-Mode, allerdings nach traditioneller Art und Weise strukturiert. Der erste Menüpunkt ist das "My Favorites"-Feature, das die Auswahl der häufig verwendeten Funktionen aus dem BIOS anzeigt, die der Nutzer frei auswählen kann. Für das Hinzufügen oder Entfernen von Funktionen muss dafür oben der Punkt "MyFavorite(F3)" angeklickt oder die Taste "F3" gedrückt werden. Dies öffnet ein eigenständiges Fenster, in dem die Funktionen ausgewählt werden können.
Auf der "Main"-Seite werden noch einmal einige Vorabinformationen wie die BIOS-Version, das installierte Prozessormodell und einige RAM-Infos angezeigt. Auch hier lässt sich die Menüsprache ändern, falls gewünscht. Sämtliche Overclocking-Funktionen sind im Extreme-Tweaker-Reiter hinterlegt worden, und es sind wieder einmal sehr viele Funktionen implementiert worden. Ob es nun um die Taktfrequenz von CPU oder Arbeitsspeicher oder doch um die einzelnen Spannungen geht, hier wird der Anwender fündig. Zur Unterstützung wird jeweils unten erklärt, was die einzelnen Funktionen bewirken.
Wie immer können die zahlreichen Onboard-Komponenten mithilfe des nächsten Reiters konfiguriert werden. Auch wenn auf der rechten Seite ständig einige Informationen vom Hardware-Monitor angezeigt werden, hat ASUS eine eigene "Monitor"-Seite umgesetzt, auf der unter anderem die Lüfter gesteuert werden können. Aber auch die Temperaturen und Spannungen werden noch einmal aufgelistet.
Sämtliche Einstellungen, die den Startvorgang betreffen, wurden auf den Reiter "Boot" geparkt. Wer sich von dem Boot-Logo gestört fühlt, kann es dort abschalten. Zusätzlich sind an dieser Stelle die Boot-Overrides untergebracht worden, die man häufig auch auf der letzten Seite findet. ASUS gibt auch hier erneut ein paar Tools mit auf den Weg. Darunter das "ASUS EZ Flash 3 Utility", womit das UEFI entweder über einen USB-Datenträger oder aber über das Internet aktualisiert werden kann. Sämtliche UEFI-Einstellungen können mithilfe des "ASUS Overclocking Profile" in maximal acht Profilen gesichert werden, die auch von einem USB-Stick exportiert und importiert werden können. "ASUS SPD Information" liest die Serial Presence Detect-Werte aus den DIMMs aus. Und unter "Exit" können die gesetzten Settings abgespeichert und auch die Default-Werte geladen werden. Bevor das UEFI die Settings abspeichert, zeigt ein kleines Fenster alle Einstellungen an, die verändert wurden. Wer sich nützliche Notizen anlegen möchte, muss glücklicherweise auf keinen Zettel und Stift zurückgreifen, sondern verwendet einfach das "Quick Note"-Feature.
Die Bedienbarkeit der UEFI-Oberfläche stufen wir als akzeptabel ein. Die Navigation kann durch die Menüs nach langer UEFI-Benutzung in meist ruckeliger Weise durchgeführt werden, was wir schon häufiger kritisieren mussten. Abgesehen von dieser Tatsache wurden alle gewählten Einstellungen zu unserer vollsten Zufriedenheit übernommen. Auch gab es an der Stabilität nichts zu bemängeln.
Mit den X870(E) und B850-Mainboards führt ASUS im eigenen UEFI das Dashboard ein, das dem Anwender einen Überblick über die Platine und auch über das I/O-Panel gibt. Gleichzeitig kann der Anwender auf einem Blick sehen, an welchen Anschlüssen eine Komponente installiert ist und ob diese funktioniert. Dies wird in Form eines grünen Punktes neben dem Anschlussnamen dargestellt. Wird mit dem Maus-Cursor auf den Anschluss gezeigt, wird dem Anwender oben rechts in der Ecke angezeigt, um welche Komponente es sich handelt.
Am Beispiel des obersten PEG-Slots wird korrekt angezeigt, dass es sich um die GeForce RTX 2060 mit dem TU106-Chip von NVIDIA handelt. Unten rechts in der Ecke hingegen kann vorab gefiltert werden, welche Art von Anschlüsse auf dem Dashboard angezeigt werden sollen.
Overclocking
Mit 13 effektiven CPU-Spulen und den zahlreichen Onboard- und BIOS-Features eignet sich das ASUS ROG Strix B850-I Gaming WiFi gut zum Übertakten. Das UEFI unterstützt auch die Down-Core-Funktion, mit der CPU-Kerne oder auch ein CCX-Modul (CPU Core Complex) gezielt abgeschaltet werden können.
Auf dem ASUS ROG Strix B850-I Gaming WiFi ist eine Veränderung des Grundtakts von 96,0000 MHz bis 118,0000 MHz in 0,0625-MHz-Schritten möglich. Bei der CPU-Spannung stehen dem Anwender der Override- und der Offset-Modus zur Auswahl. Im Override-Modus lässt sich die Spannung von 0,80000 V bis 1,55000 V in 0,00500-V-Intervallen verändern. Der Offset-Modus hingegen erlaubt die Veränderung der CPU-Spannung von -0,50000 V bis +0,50000 V in ebenfalls 0,00500-V-Schritten. Die Arbeitsspeicher-Taktraten reichen von 2.000 MHz bis 12.000 MHz. Alle weiteren Overclocking-Funktionen können der folgenden Tabelle entnommen werden. Wird der CPU-Extreme-Overvoltage-Jumper umplatziert und das Feature aktiviert, lassen sich zwei Spannungen noch weiter erhöhen. Diese Maximal-Werte haben wir in Klammern gesetzt.
| Die Overclocking-Funktionen des ASUS ROG Strix B850-I Gaming WiFi in der Übersicht | |
| Base Clock Rate | 96,0000 MHz bis 118,0000 MHz in 0,0625-MHz-Schritten |
| CPU-Spannung | 0,80000 V bis 1,55000 V in 0,00500-V-Schritten (Override-Modus) -0,50000 V bis +0,50000 V in 0,00500-V-Schritten (Offset-Modus) |
| DRAM-Spannung | 0,80000 V bis 2,07000 V in 0,01000-V-Schritten (Fixed-Modus) |
| CPU-SoC-Spannung | 0,80000 V bis 1,30000 V in 0,00500-V-Schritten (Fixed-Modus) -0,50000 V bis +0,50000 V in 0,00500-V-Schritten (Offset-Modus) |
| CPU-VDDIO/MC-Spannung | 1,10000 V bis 1,7000 V (2,20000 V) in 0,01000-V-Schritten (Fixed-Modus) |
| CPU-VDDP18-Spannung | 1,80000 V bis 2,20000 V (3,0000 V) in 0,00500-V-Schritten (Fixed-Modus) |
| CPU-VDDP-Spannung | 0,700 V bis 1,800 V in 0,001-V-Schritten (Fixed-Modus) |
| PCH-Core-Spannung | 1,05000 V bis 1,20000 V in 0,00500-V-Schritten (Fixed-Modus) |
| PCIe-Takt | - nicht möglich - |
| Weitere Spannungen | 1,8 V Standby, Misc, DRAM VDD(Q), DRAM VPP |
| Speicher-Optionen | |
| Taktraten | CPU-abhängig |
| Command Rate | einstellbar |
| Timings | 31 Parameter |
| XMP/EXPO | wird unterstützt |
| Weitere Funktionen | |
| Weitere Besonderheiten | UEFI-BIOS Settings speicherbar in Profilen Turbo-Modus (Core Performance Boost, All Cores, By number of active cores), erweiterte Lüfterregelung für CPU-Fan und fünf optionale Fans, LLC Level 1 bis 8 |
Unser Ryzen 7 7700X macht 5,4 GHz auf allen acht Zen-4-Kernen mit. Das ROG Strix B850-I Gaming WiFi hatte Probleme, diesen Takt zu halten und das System war instabil. Wir sind dann auf den 53er Multiplikator zurückgegangen, mit dem das Mini-ITX-Mainboard dann zurechtkam. Allerdings waren hierfür 1,190 Volt notwendig, die für den Takt von 5,3 GHz schon eher erhöht sind.
Der verbaute 30-mm-Axiallüfter kann im BIOS auf Wunsch deaktiviert werden. Als einzige Einstellmöglichkeiten bieten sich Full-Speed, PWM Mode und Disabled an. Demnach kann keine manuelle Lüfterkurve gesetzt werden. Positiv anzumerken ist, dass der Lüfter bei Volllast und bei einer Raumtemperatur von 22 °C nicht angesprungen ist.
Gerade die Mini-ITX-Mainboards bieten beim RAM-OC den Vorteil, dass die beiden DRAM-Bänke dicht beim CPU-Sockel positioniert sind. So war es keine Überraschung, dass die 4.000 MHz für den DDR5-8000-Betrieb kein Problem war.
Kleiner Nebeneffekt seitens CPU-Z: Der Fehler mit der Channel-Anzeige bei AM5-Systemen (2x 32 Bit anstatt korrekterweise 4x 32 Bit) wurde mit der Version 2.16 endlich gefixt.
VRM-Wärmebild-Analyse
Um die Hitzeentwicklung des VRM-Bereichs besser beurteilen zu können, haben wir für diesen Test die Flir One Pro (Android USB-C) eingesetzt, die für unser Einsatzgebiet absolut ausreichend ist und Temperaturen von -20°C bis +400°C mit einer Genauigkeit von ±3°C oder ±5%, je nach Umgebungstemperatur, erfassen kann. Die Wärmebild-Auflösung beträgt 160 x 120 Pixel und das erstellte Bild löst mit 1.440 x 1.080 Pixel auf.
Der Prozessor wird unter Berücksichtigung der BIOS-Default-Settings mit Prime95 unter Volllast gesetzt. Nach 30 Minuten Laufzeit erstellen wir das Wärmebild.
Der VRM-Kühler blieb mit nicht einmal 35°C regelrecht kühl. In der Nähe des AM5-Sockels wurden Temperaturen um die 50°C erreicht, die im Rahmen sind.
