hab grad n test über mein controller laufen lassen und Als tipps hat mir sandra diese warning gebracht:
Warning W3104 - Current transfer mode not optimal, i.e. not highest supported. This affects drive performance. If the controller is also capable of the highest supported transfer mode, there is no reason not to use it.
Fix: First check controller supported transfer modes. Then check the mode the driver for the controller/BIOS is set to use and modify; some default to a lower mode for compatibility. You may need to install newer drivers if the current drivers do not natively support the controller (especially for RAID). You may need to update the controller BIOS or drive firmware, if the mode does not stick. If data corruption occurs verify the cable and consider switching (if any) drives on the same channel onto other channels.
If the built-in controller does not support the mode, consider using the on-board/RAID controller or even disable the built-in controller and install a new controller.
SiSoftware Sandra Help File
Klar kann ich englisch aber ich hab die aktuellsten Treiber drauf und auch die aktuelle bios vers...... also wären paar tipps eurerseits ned schlecht weil n bitschen mehr performence wär schon g0il0
ich will den max speed
