Trillian Pro 4.0 (Astra) Alpha 41
Vista
Urgestein
im PC
Trillian is a fully featured, stand-alone, skinnable chat client that supports AIM, ICQ, MSN, Yahoo Messenger, and IRC. It provides capabilities not possible with original network clients, while supporting standard features such as audio chat, file transfers, group chats, chat rooms, buddy icons, multiple simultaneous connections to the same network, server-side contact importing, typing notification, direct connection (AIM), proxy support, encrypted messaging (AIM/ICQ), SMS support, and privacy settings.
* Changes in 4.0.0.41:FIXED: [Contact List] Cobalt tabbed interface without identity p... (Pak-Kei Mak)
* FIXED: Colbalt Tabbed interface tabs wrapping to next line when ... (Pak-Kei Mak)
* FIXED: Cordonata message window top corners not transparent on X... (Pak-Kei Mak)
* FIXED: File transfer image broken (Pak-Kei Mak)
* FIXED: Baroque Theme Problems on Second Monitor (grrr broke again so this doesnt count) (Pak-Kei Mak)
* FIXED: No ***** Taskbar Icon for Message Windows (Pak-Kei Mak)
* FIXED: Add Vista icons for the trillian executable (Pak-Kei Mak)
* FIXED: [YAHOO] Passwords with symbols/special characters fail (Scott Werndorfer)
* FIXED: [YAHOO] Selecting Disconnect/Close Connection does not always disconnect you from the Yahoo service. (Scott Werndorfer)
* FIXED: [YAHOO] Yahoo contact idle time is not functioning properly (Scott Werndorfer)
* FIXED: [Crash] Crash when closing a conversation in a tabbed window (Kevin Kurtz)
* FIXED: [Message Window] Invite contacts partially locks (Kevin Kurtz)
* FIXED: [Music] iTunes support readded without interface lag and lockups (Kevin Kurtz)
* FEATURE: Awesome new high resolution Vista icons for Trillian~! :-9 (dance)
* FEATURE: New 48x48 Notifier icons for all services
* Changes in 4.0.0.40:FIXED: [Events] Support for the windows key in the automation hotkey area (Kevin Kurtz)
* FIXED: [Message Windows] Enhanced information: Umlauts broken (Kevin Kurtz)
* FIXED: [Message Windows] Insert Menu Tidy up :) (Kevin Kurtz)
* FIXED: [Message Window] Alpha window + focus line (Kevin Kurtz)
* FIXED: [Skin Related] Redraw required on WM_MOVE (Kevin Kurtz)
* FIXED: [SkinXML] does not seem to take any variables (Kevin Kurtz)
* FIXED: [Vista] Message window makes scroll wheel decrease desktop icon size (Kevin Kurtz)
* FIXED: [YAHOO] Mobile icon is absent for users running a mobile version of Yahoo Messenger (Scott Werndorfer)
* FIXED: [YAHOO] Unable to connect to Yahoo - build 39 problems (Scott Werndorfer)
* FIXED: Jabber orphans (Rachel Blackman)
* REMOVED: Removed iTunes integration until bug can be fixed (Kevin Kurtz)
* REMOVED: Alpha from message windows until bugs and speed are addressed (Pak-Kei Mak)
* ADDED: Split Icon Pack into System Icon Pack and Service Icon Pack
* ADDED: Baroque Theme for Cordonata
* Changes in 4.0.0.39:FIXED: [YAHOO] "This user is offline" annoyance (Scott Werndorfer)
* FIXED: [YAHOO] Add Block/etc to contact list RC menu (Scott Werndorfer)
* FIXED: [YAHOO] Add User Info to contact list RC menu (Scott Werndorfer)
* FIXED: [YAHOO] Add User Info to message window RC menu (Scott Werndorfer)
* FIXED: [YAHOO] As of build 34, the Yahoo status window no longer shows contacts' status changes (Scott Werndorfer)
* FIXED: [YAHOO] Import mail alert setting from 3.1 (or enable by default) (Scott Werndorfer)
* FIXED: [YAHOO] Improper checking for valid accounts on contact add with MSN, Jabber (Scott Werndorfer)
* FIXED: [YAHOO] Incoming file transfer results in Error: Code 404 after Astra has been running for an extended period. (Scott Werndorfer)
* FIXED: [YAHOO] Invisible contacts disregard renaming in message windows (Scott Werndorfer)
* FIXED: [YAHOO] MSN interoperability (Scott Werndorfer)
* FIXED: [YAHOO] Yahoo away state lost after reconnect (Scott Werndorfer)
* FIXED: [YAHOO] Yahoo connection error code 14 is account locked out for 12 hours (Scott Werndorfer)
* FIXED: [GOOGLE] Google add causes disconnect (Rachel Blackman)
* FIXED: [GOOGLE] Google keeps disconnecting and reconnecting (Rachel Blackman)
* FIXED: [JABBER] Jabber failing to HTML-decode XHTML message packets (Rachel Blackman)
* FIXED: [JABBER] Jabber orphans (Rachel Blackman)
* FIXED: [JABBER] On 3.1 --> 4.0 Upgrade, Jabber/GoogleTalk connections lost (Rachel Blackman)
* FIXED: [JABBER] Second identity seems to cause crashes (Rachel Blackman)
* FIXED: [JABBER] Google talk alternate port is not supported (Rachel Blackman)
* FIXED: No "user is typing" indication in tabbed message window. (Pak-Kei Mak)
* FIXED: ***** Icon is missing in task bar (Pak-Kei Mak)
* FIXED: Fixed Alpha Transparency edges in contact list (Pak-Kei Mak)
* FIXED: Fixed non-alpha problems in File Transfer and Notifier windows (Pak-Kei Mak)
* FIXED: Cleaned up some old codes from Cordonata (Pak-Kei Mak)
* FIXED: [Skins] Better Font opacity on transparent backgrounds (Kevin Kurtz)
* Core: New core.dll exposes network API for plugins to use - yahoo.dll the first DLL to use it. core.dll is better than full Tier 6.
* Containers: Change focus of tabs using the ctrl+# keys
* Skin: Added Vista Glass support for Notifiers
* Skin: Added Vista Glass support for Private Message Windows
* Skin: Notifier icons/avatar size is now 48x48 and added some new icons
* Skin: Added icons for IRC, LCS, NOVELL, QQ, BONJOUR, SAMETIME, SKYPE, XFIRE
* Skin: New Helper icons for all services
* Skin: Cordonata File Transfer now shows error note even when transfer is slow
* Skin: Lightened up ICQ icon
* Changes in 4.0.0.38:FIXED: Ampersand (&) causes Jabber to disconnect (Rachel Blackman)
* FIXED: Jabber failing to log in to eJabberd server (Rachel Blackman)
* FIXED: Subscription Context Features (Rachel Blackman)
* FIXED: [Contact List] can't collapse/open 'sections' on second monitor (Kevin Kurtz)
* FIXED: [Install] Skin preference forgotten after new build installed (Kevin Kurtz)
* FIXED: [Install] Upgrade from Trillian 3.1 to Astra causes issues with contact icons (Kevin Kurtz)
* FIXED: [Message Window] Root tabbed containers titled Unknown Translation! (Kevin Kurtz)
* FIXED: [Message Window] Weird buddy icon synchronizing (Kevin Kurtz)
* FIXED: [Skin Related] Trillian.dtd does not upgrade (Kevin Kurtz)
* FIXED: [Stixe] Emoticons reset to default after update (Kevin Kurtz)
* XMPP: Support for Last Activity (XEP-0012)
* XMPP: Support for legacy Entity Time (XEP-0090)
* XMPP: Support for Entity Time (XEP-0202)
* Skin: Brand new shiny chat service icons!~
* Message Windows: New Messages Count in Taskbar Entry
* Contact List: Sort contact list by log file size
* Contact List: Option to remove avatars from contact list but still change icon size
* Contact List: Right click on contact list frame yields file menu
* Changes in 4.0.0.37:FIXED: [AV] Video & Audio Preferences truncates names of Speaker Output Devices, and CJK bug (Kevin Kurtz)
* FIXED: [Browser] Trillian doesn't obey default browser settings (Kevin Kurtz)
* FIXED: [Contact List] Auto expand does not always contract as expected (Kevin Kurtz)
* FIXED: [Contact List] Contact List display not always in sync with Contact List Preference (Kevin Kurtz)
* FIXED: [Contact List] Do not kill selection when you clear your search (Kevin Kurtz)
* FIXED: [Contact List] Do not resort if the contact name stays the same on rename (Kevin Kurtz)
* FIXED: [Contact List] Renaming a subaccount of a metacontact in tile view shows no UI (Kevin Kurtz)
* FIXED: [CPU Specific] "Website cannot be displayed" when adding widgets (Kevin Kurtz)
* FIXED: [Crash] Crash when renaming a non metacontact (Kevin Kurtz)
* FIXED: [Request] %window.blur%? (Kevin Kurtz)
* FIXED: [Request] Change Root container's title to section name (Kevin Kurtz)
* FIXED: [Request] scrolltop and scrollbottom icontrol type (Kevin Kurtz)
* Changes in 4.0.0.36:FIXED: [Google Talk] 5 characters from sent messages trimmed (Rachel Blackman)
* FIXED: Non-authorized jabber contact causes crash (Rachel Blackman)
* FIXED: [Jabber] Denied Authorization --> Contact On Roster? (Rachel Blackman)
* FIXED: [SKIN FEATURE] Cobalt-Tabbed Interface-Options (Pak-Kei Mak)
* FIXED: Tabbed Interface-Option To Remove Identity Panel (Pak-Kei Mak)
* FIXED: Template buttons have wrong text color (Pak-Kei Mak)
* FIXED: Default text color in Dark themes (Pak-Kei Mak)
* FIXED: No close button on Add bar (Pak-Kei Mak)
* FIXED: [Login] Pre-Logon Proxy Preferences --> Wrong Tab Order (Kevin Kurtz)
* FIXED: [Login] Welcome to Trillian screen has no way to change Astra login settings (Kevin Kurtz)
* FIXED: [Events] Away mode in German Version doesn't work correct (Kevin Kurtz)
* FIXED: [Installer] New installer does not remember location of last installation (Kevin Kurtz)
* FIXED: [Contact List] File Transfer to Wrong Contact (Kevin Kurtz)
* FIXED: [Contact List] resort contact list on rename (Kevin Kurtz)
* FIXED: [Contact List] Tiles don't respond well to mouse movement. (Kevin Kurtz)
* FIXED: [Contact List] Trillian doesn't remember docking state (Kevin Kurtz)
* FIXED: [Container] Root-level Astra contacts open in wrong containers (Kevin Kurtz)
* XMPP: Better communication of subscription state.
* Changes in 4.0.0.35:FIXED: [Activity History] Conversation text not showing in history viewer (Kevin Kurtz)
* FIXED: [Away inconsistencies] Cordonata skin: "New Away Message" button does nothing (Kevin Kurtz)
* FIXED: [Installer] wording on installer (Kevin Kurtz)
* FIXED: [Login] Unchecking the "Use proxy server" checkbox on the "Welcome to Trillian" screen does not actually stop proxy usage (Kevin Kurtz)
* FIXED: [Message Window] Tooltip incorrect for message entry area when in pen mode. (Kevin Kurtz)
* FIXED: [Profile] Rendezvous accounts should not be saved on the profile-server (Kevin Kurtz)
* FIXED: [Skin Related] Trillian -> Add contact (Kevin Kurtz)
* FIXED: [Speed] Edit text area lags in message window.. (Kevin Kurtz)
* FIXED: [Updater] music and timezone updater plugins disable themselves (Kevin Kurtz)
* FIXED: Minimal interface issues (Pak-Kei Mak)
* FIXED: Minimal Interface Notifiers now use 16x16 (Pak-Kei Mak)
* FIXED: Removed hide and minimize buttons from Cordonata tabbed contact list, and added Detach button (Pak-Kei Mak)
* FIXED: Skin problems involving collapsing/expanding Contact List sections (Pak-Kei Mak)
* FIXED: What happened to the Milk Theme on Cordonata (Pak-Kei Mak)
* FIXED: [Cordonata Black] white-background-shine @ Option Bar (| Trillian | View | Window | Help |) (Pak-Kei Mak)
* FIXED: [SDK] right_icons not showing up on groups (Pak-Kei Mak)
* FIXED: [Skin Related] Expand/collapsed sections when using Colbalt Minimal (Pak-Kei Mak)
* FIXED: [Skin Related] First time using Colbalt Tabbed interface = empty interface (Pak-Kei Mak)
* Message Window: Insert Video capture
* XMPP: Support for XEP-0115 capsets in message stanzas, for contacts not in the roster.
* XMPP: Read-only support for non-standard XEP-0115 variants, such as GizmoProject uses.
* XMPP: Improvements to subscription/roster engine.
* Changes in 4.0.0.34:FIXED: AIM Filetransfer failing with 0.0.0.0 IP (Scott Werndorfer)
* FIXED: An idle Yahoo contact who has a custom message set is never shown as idle (Scott Werndorfer)
* FIXED: Astra frequesntly prompts with ICQ "permission to add" requests (Scott Werndorfer)
* FIXED: Group Conversations (Scott Werndorfer)
* FIXED: Not Able To Connect To MySpace IM (NEW) (Scott Werndorfer)
* FIXED: Quotes in away message not displaying properly and online time not calculating properly (Scott Werndorfer)
* FIXED: random crash, again (Scott Werndorfer)
* FIXED: Unable to login to @msn.com account (Scott Werndorfer)
* FIXED: With a custom status message is set, Astra never sets you as idle (Scott Werndorfer)
* FIXED: Yahoo contacts' idle status not properly reflected on Astra contact list. (Scott Werndorfer)
* FIXED: Crashed while Idle (Kevin Kurtz)
* FIXED: [Activity History] search results overwrite date (Kevin Kurtz)
* FIXED: [Contact List] When hovering over Away message in ID Panel, tooltip simply extends offscreen rather than wrapping. (Kevin Kurtz)
* FIXED: [Message Window] Spaces in hyperlink URL cause incorrect browser launching (Kevin Kurtz)
* FIXED: Google talk plugin likes to report the number of ***** messages a bit often! (Rachel Blackman)
* FIXED: [Jabber] Cannot delete Jabber plugin (Rachel Blackman)
* FIXED: [Jabber] Sign-on/offline message flaw (Rachel Blackman)
* Installer: Revamped into the new millennium.
* XMPP: Added support for 'gone' chat state on window close.
* XMPP: More intelligent caching of XEP-0115 caps bits.
* XMPP: Added support for XEP-0071 (XHTML-IM).
* Changes in 4.0.0.33:FIXED: Astra crashes when importing old settings. (Scott Werndorfer)
* FIXED: custom away messages: N/A status on ICQ not properly imported from prev. version (Scott Werndorfer)
* FIXED: [Forums] PHP: Allowed memory size exhausted (Scott Werndorfer)
* FIXED: Trillian crashed when the laptop was idle during the night. (Kevin Kurtz)
* FIXED: [Contact List] Translation unknown "Add" button tooltip build 31 (Kevin Kurtz)
* FIXED: [Container] Tabbed Typing Indicator Doesn't Reset (Kevin Kurtz)
* FIXED: [Login] Switching language on login only switches it temporarily (Kevin Kurtz)
* FIXED: [Message Window] Containers grabbing focus when not needed (Kevin Kurtz)
* FIXED: [Message Window] Emoticons dont show when attached to a letter/word (Kevin Kurtz)
* FIXED: [Message Window] Problem with Umlauts, when inserting a link from a browser (Kevin Kurtz)
* FIXED: [Skin Related] Send Button Does Not Disappear (Kevin Kurtz)
* FIXED: [Skin Related] When specifying a default theme in a skin, the original state should be hideable (Kevin Kurtz)
* FIXED: [Skin Switch] Glass does not turn off when the next skin does not need it (Kevin Kurtz)
* FIXED: [Systray Alerts] Auth request Tray Notifications Are Persistent (Kevin Kurtz)
* FIXED: [Languages] Contact List Window is empty (Kevin Kurtz)
* FIXED: [Jabber] Server imported Jabber connections reset to jabber.org (Rachel Blackman)
* XMPP: Added support for Service Discovery (XEP-0030).
* XMPP: Added support for Entity Capabilities (XEP-0115).
* XMPP: Added support for Chat State Notifications (XEP-0085).
http://www.computerbase.de/downloads/softw...ation/trillian/
:d
ich finde, das Leben ist zu kurz , um sich mit Alpha-Versionen herumzuschlagen........
Was soll uns dieser Topic sagen ???
zumal:
Die Alpha-Version Trillian Astra 4 ist nur vorher registrierten Testern zugänglich.
Mir persönlich fehlt da noch die individuelle invisible-einstellung für die einzelnen Kontakte.
Das fand ich bei 3.1 immer sehr praktisch.
Jetz muss man sich durchs Menü friemeln... :(
Ansonsten läuft die Version bei mir sehr stabil und flüssig und sogar Datentransfer klappt manchmal... :shot:
Die ganzen Alpha Versionen interessieren mich nicht, mich würde mal viel mehr interessieren wann endlich mal ne Beta kommt, bzw. das fertige Trillian Astra...
Ist zwar schon was älter, aber es gibt jetzt ne Beta ^^
Habe auch direkt ma ne Frage:
Wenn ich Leute aus ICQ in der Liste habe sehe ich nur die ICQ Nummer, nicht den ICQ namen, das nervt etwas.
Weiß jemand wie man das ändern kann?
MfG
hi, ich hab mal ne frage habe heute win7 installiert und trillian astra
nun wollt ich mit meinem account einlogen aber weiß das passwort nichtmehr >.<
kann man sich das zuschicken lassen ?
Ja, funktioniert aber nicht - ich warte seit 2 Monaten auf meine (neuen) Zugangsdaten :fresse:
Dito. Das dauert einfach viel zu lange.
Servus,
Ich habe folgendes Problem:
Ich habe mir einen Astra Acc angelegt und mic auch mit meinen bisheriger ICQ Acc dort eingeloggt.
Soweit so gut. Nun habe ich das Problem das sobald ich den Rechner neustarte mein ICQ Acc neu Eintragen muss. D.h ICQ Nr. und PW was mich auf dauer doch etwas nervt.
Jemand eine Idee zur Lösung des Problemes?
Vielen Dank
