Steelpad Tastatur - Steel Keys 6G
pantherklaus
localhost
Habe ich durch Zufall gefunden:
http://www.gdex.co.jp/?mode=search&pattern=detail&itemid=401-10129 (Übersetzung)
http://www.rakuten.co.jp/gdex/542027/603799/616827/ (Übersetzung)
Kann hier jemand japanisch oder hat nen Übersetzter? =)
thx @ insi =)
Sieht nach einer Tastatur von Steelpad aus, jedoch ist auf der Webseite von Steelpad dazu noch nicht viel zu finden. In dem Text steht was mit Cherry, daher denke ich, dass es eine Cherry sein wird, die nach den Wünschen von Steelpad (Soft Trading) umgestaltet wurde (vom Preis her würde es passen. Kosten beide viel zu viel =) ).
Erscheinungstermin: 20.10.2005 (sieht zumindest so aus =) ).
Preis: 15,800 JPY (~ 115,00 - 120,00 EUR)
< Summary >
Worldwide beginning! The eSport private gaming keyboard completes!
It is the super durability high quality gaming keyboard which can adopt the up-to-date Kith itch of the Cherry corporation, withstand also the increase of 200 kg!
The Steel keys 6g in the cost performance which is not so far, supports the ????!
< Formality HP / details >
Https: //www.steelpad.com/
< Specification >
Mechanical switch
? key life 6 10000000 time
There is no ? axis and there is no misconception recognition
When sound of the ? key does, because you have recognized, it is not necessary to push the key to the inner part it is efficient and load does not fall on the wrist.
The gold is used in the ground part of the ? key, the signal reaches efficiently at high speed.
There is a sense of security in ? key touch, it is comfortable and you use and the selfishness is splendid, is.
< Durability >
As for the ? Steel Keys 6g it is possible to withstand the load of the 200kg. Dropping into the floor absent-mindedly, completely, there is no problem.
There are no times to which quality of ? letter print is good very much, goes out.
< Human engineering >
The occasion where the ? keyboard is struck, it has made the angle which is optimum to the wrist.
In order ? long time to be able to use, the key top is designated as the angle which is suited for the typing.
Each key of the ? Steel Keys 6g elasticity is better than the membrane keyboard, it has reached the point where load does not fall on the wrist even in all circumstances.
< Performance >
The ground part of the Steel Keys 6g does with the gold, the key reaction to be quicker than the membrane keyboard is accurate.
Impedance of the usual membrane keyboard is 28 ohm from 20.
Therefore, lag occurs in the connection reaction of the key, but impedance of the Steel Keys 6g which uses the gold for the key ground part is close to 0, is. Therefore one time it grounds directly to react, there is no delay, types how quickly and there is no misconception recognition.
Wenn die keine besonderen Features haben sollte find ich das auch ganz schön teuer im Vergleich zum Logitech G15 z.B.
Das kann uns nur wer beantworten, der auch japanisch kann. Vorher wird wohl keiner erfahren, ob die was besonderes kann.
die völlig unnötig sind. die g15 ist so ziemlich das sinnloseste was ich kenne.
C3PL1O schrieb:
warum isn die so teuer, so hochwertig sieht die garnich aus.
gibt auch innere wertte und wenn ich das richtig peile sind die auch brauchbar.
