_________________________________________________________________________________________________________
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:11:10 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-B27UNKD
OS version: Windows 10, 10.0, version 2004, build: 19041 (x64)
Hardware: MS-7B79, Micro-Star International Co., Ltd.
CPU: AuthenticAMD AMD Ryzen 5 2600X Six-Core Processor
Logical processors: 12
Processor groups: 1
RAM: 16335 MB total
CPU SPEED
Reported CPU speed: 360 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 101547,263689
Average measured interrupt to process latency (µs): 87,633463
Highest measured interrupt to DPC latency (µs): 101537,346227
Average measured interrupt to DPC latency (µs): 56,603829
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 990,820
Driver with highest ISR routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total ISR routine time (%): 0,281482
Driver with highest ISR total time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in ISRs (%) 0,287078
ISR count (execution time <250 µs): 353716
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 2542
ISR count (execution time 1000-2000 µs): 0
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 1955,40
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 452.06 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0,190193
Driver with highest DPC total execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in DPCs (%) 0,413118
DPC count (execution time <250 µs): 1092141
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 12377
DPC count (execution time 1000-2000 µs): 12
DPC count (execution time 2000-4000 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: firestone.exe
Total number of hard pagefaults 8996
Hard pagefault count of hardest hit process: 1604
Number of processes hit: 56
PER CPU DATA
CPU 0 Interrupt cycle time (s): 122,166467
CPU 0 ISR highest execution time (µs): 990,820
CPU 0 ISR total execution time (s): 22,708842
CPU 0 ISR count: 308527
CPU 0 DPC highest execution time (µs): 1955,40
CPU 0 DPC total execution time (s): 30,904687
CPU 0 DPC count: 982627
CPU 1 Interrupt cycle time (s): 17,500774
CPU 1 ISR highest execution time (µs): 236,490
CPU 1 ISR total execution time (s): 0,245409
CPU 1 ISR count: 24245
CPU 1 DPC highest execution time (µs): 489,280
CPU 1 DPC total execution time (s): 0,687598
CPU 1 DPC count: 28727
CPU 2 Interrupt cycle time (s): 14,233567
CPU 2 ISR highest execution time (µs): 333,510
CPU 2 ISR total execution time (s): 0,127132
CPU 2 ISR count: 4291
CPU 2 DPC highest execution time (µs): 639,210
CPU 2 DPC total execution time (s): 0,386246
CPU 2 DPC count: 37990
CPU 3 Interrupt cycle time (s): 13,088773
CPU 3 ISR highest execution time (µs): 194,130
CPU 3 ISR total execution time (s): 0,002590
CPU 3 ISR count: 75
CPU 3 DPC highest execution time (µs): 286,470
CPU 3 DPC total execution time (s): 0,132419
CPU 3 DPC count: 5999
CPU 4 Interrupt cycle time (s): 13,038878
CPU 4 ISR highest execution time (µs): 0,0
CPU 4 ISR total execution time (s): 0,0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 646,490
CPU 4 DPC total execution time (s): 0,184147
CPU 4 DPC count: 9433
CPU 5 Interrupt cycle time (s): 13,085722
CPU 5 ISR highest execution time (µs): 0,0
CPU 5 ISR total execution time (s): 0,0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 216,510
CPU 5 DPC total execution time (s): 0,075243
CPU 5 DPC count: 2802
CPU 6 Interrupt cycle time (s): 14,194131
CPU 6 ISR highest execution time (µs): 0,0
CPU 6 ISR total execution time (s): 0,0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 345,290
CPU 6 DPC total execution time (s): 0,212968
CPU 6 DPC count: 9318
CPU 7 Interrupt cycle time (s): 14,072458
CPU 7 ISR highest execution time (µs): 0,0
CPU 7 ISR total execution time (s): 0,0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 317,710
CPU 7 DPC total execution time (s): 0,076059
CPU 7 DPC count: 2738
CPU 8 Interrupt cycle time (s): 13,891490
CPU 8 ISR highest execution time (µs): 119,790
CPU 8 ISR total execution time (s): 0,021143
CPU 8 ISR count: 15153
CPU 8 DPC highest execution time (µs): 493,750
CPU 8 DPC total execution time (s): 0,232260
CPU 8 DPC count: 10429
CPU 9 Interrupt cycle time (s): 13,286668
CPU 9 ISR highest execution time (µs): 15,040
CPU 9 ISR total execution time (s): 0,000689
CPU 9 ISR count: 379
CPU 9 DPC highest execution time (µs): 300,110
CPU 9 DPC total execution time (s): 0,098009
CPU 9 DPC count: 3018
CPU 10 Interrupt cycle time (s): 13,866560
CPU 10 ISR highest execution time (µs): 29,40
CPU 10 ISR total execution time (s): 0,002790
CPU 10 ISR count: 1137
CPU 10 DPC highest execution time (µs): 299,120
CPU 10 DPC total execution time (s): 0,155187
CPU 10 DPC count: 7036
CPU 11 Interrupt cycle time (s): 13,891050
CPU 11 ISR highest execution time (µs): 112,020
CPU 11 ISR total execution time (s): 0,006358
CPU 11 ISR count: 2451
CPU 11 DPC highest execution time (µs): 293,110
CPU 11 DPC total execution time (s): 0,118633
CPU 11 DPC count: 4413
