Vista
Urgestein
- Ort
- im PC
- Desktop System
- System Wahnwitz
- Laptop
- Intel Xeon W-3175X, 28C/56T, 3.10-3.80GHz LGA3647
- Asus ROG Dominus Extreme LGA3647
- Phanteks Glacier Dominus Extreme Kit CPU+VRMs
- Corsair Dominator RGB DDR4-4000 MHZ CL19 12 x 16 GB
- Asus ROG Matrix GeForce RTX 4090 Platinum 24GB GDDR6X
- Philips 43 Zoll 4K
- Samsung 970 Evo Plus 2TB + 980 Pro 1TB + 990 Pro 4TB
- HDD
- 3x Toshiba MG09 18 TB
- Opt. Laufwerk
- ASUS Blu-Ray Laufwerk
- Soundkarte
- Creative AE-5 Plus + Lightning Kit
- Thermaltake W200 Core + 2x Thermaltake P200 Core
- 2x Corsair AX1600i
- Keyboard
- Corair K100 Gold + Corsair Nexus
- Mouse
- Corsair + MM800 RGB Cloth
- Windows 10 Pro for Workstation
- Webbrowser
- Firefox, Edge, Opera, Chrome
- Sonstiges
- Mo-Ra 420 Pro Steel Push/Pull Noctua a20 HP
- Internet
- ▼100 MBit ▲30 MBit
ftp://ftp1.usw.nero.com/software/Nero7/Nero-7.2.3.2b_deu_no_yt.exe
happy burning
Version number 7.2.3.2
Release Date: 06/23/2006
Changes/Bugfixes
-Nero Burning ROM and Nero Express crashed after the DEMO version had expired.
-Bad, scratchy sound when encoding files to mp3 using the 'standard' settings
-Multisession was not automatically selected when burning to the image recorder
-UNC support of Nero did not work anymore, so continuing a multi session CD with UNC paths did not work
-Nero Burning ROM did not use the selected partition to create a boot CD
-Nero Express crashed under Windows 98 when adding protected WMA files to a compilation
-Nero Burning ROM had graphical problems under Windows 98 when changing the menu options any kind of animation
-It was possible to select the ISO file system view in the folder panel of the compilation, although a UDF compilation was chosen
-Error message was shown when starting to convert Audio CDs to Nero Digital Audio
happy burning
