Bei mir springt die Vcore auch stark..
IDLE
CPU with Hyper-Threading technology detected.
You should run two copies of SP2004 simultaneously.
CPU: 3901MHz FSB: 260MHz [260MHz x 15.0 est.]
Using existing MBM info
25.09.2004 16:10 0 minutes
Temperature: Case: 26.00
Temperature: CPU: 45.00
Temperature: PWM: 45.00
Voltage: V-Core: 1.63
Voltage: Mushkin LII: 2.75
Voltage: +3.3: 3.18
Voltage: +5.00: 4.94
Voltage: Enermax: 11.67
Voltage: DDR VTT: 1.36
Voltage: AGP VDDQ: 1.55
Voltage: VBAT: 3.26
Voltage: 5VBS: 4.94
LAST
Beginning a continuous self-test to check your computer.
Please read stress.txt. Choose Test/Stop to end this test.
Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
1 minute
Temperature: CPU: 50.00
Temperature: PWM: 47.00
Voltage: V-Core: 1.55
Voltage: +3.3: 3.15
Voltage: Enermax: 11.43
Voltage: VBAT: 3.24
Voltage: 5VBS: 4.92
2 minutes
Temperature: PWM: 50.00
Voltage: V-Core: 1.56
Voltage: Mushkin LII: 2.73
Voltage: +3.3: 3.13
Voltage: Enermax: 11.49
Voltage: VBAT: 3.26
3 minutes
Temperature: CPU: 51.00
Temperature: PWM: 51.00
Voltage: V-Core: 1.60
Voltage: AGP VDDQ: 1.53
Test 2, 4000 Lucas-Lehmer iterations of M19922943 using 1024K FFT length.
4 minutes
Temperature: PWM: 52.00
Voltage: Mushkin LII: 2.76
Voltage: +3.3: 3.15
Voltage: DDR VTT: 1.34
Voltage: VBAT: 3.24
5 minutes
Temperature: CPU: 52.00
Temperature: PWM: 53.00
Voltage: +3.3: 3.13
Voltage: VBAT: 3.26
6 minutes
Temperature: Case: 27.00
Temperature: PWM: 54.00
Voltage: VBAT: 3.24
7 minutes
Test 3, 4000 Lucas-Lehmer iterations of M19374367 using 1024K FFT length.
8 minutes
Voltage: VBAT: 3.26
9 minutes
Temperature: PWM: 55.00
Voltage: +3.3: 3.15
Voltage: VBAT: 3.24
10 minutes
Voltage: V-Core: 1.58
Voltage: VBAT: 3.26
Test 4, 4000 Lucas-Lehmer iterations of M19174369 using 1024K FFT length.
11 minutes
Voltage: +3.3: 3.13
12 minutes
Temperature: PWM: 56.00
13 minutes
Voltage: +3.3: 3.15
Voltage: VBAT: 3.24
14 minutes
Voltage: +3.3: 3.13
Voltage: VBAT: 3.26
Test 5, 4000 Lucas-Lehmer iterations of M18874369 using 1024K FFT length.
15 minutes
Voltage: +3.3: 3.15
16 minutes
Voltage: VBAT: 3.24
17 minutes
Voltage: VBAT: 3.26
Self-test 1024K passed!
Test 1, 4500 Lucas-Lehmer iterations of M17432577 using 896K FFT length.
18 minutes
Voltage: +3.3: 3.13
19 minutes
Voltage: +3.3: 3.15
Voltage: VBAT: 3.24
20 minutes
Voltage: +3.3: 3.13
21 minutes
Test 2, 4500 Lucas-Lehmer iterations of M17432575 using 896K FFT length.
22 minutes
Voltage: +3.3: 3.15
23 minutes
24 minutes
Test 3, 4500 Lucas-Lehmer iterations of M17115073 using 896K FFT length.
25 minutes
Voltage: +3.3: 3.13
26 minutes
27 minutes
28 minutes
Test 4, 4500 Lucas-Lehmer iterations of M16815071 using 896K FFT length.
29 minutes
Voltage: +3.3: 3.15
30 minutes
Voltage: +3.3: 3.13
31 minutes
Voltage: +3.3: 3.15
