Mainboard mit speziellen Anforderung gesucht!
drzeissler
Guten Abend,
welches Mainboard (Chipsatz/CPU egal) wird noch vollständig von Win2K unterstützt ?
Hier die vollständige Prio-Liste:
1. Treiber für Windows 2000
2. Mindestens 3x PCI
3. Kein Onboard VGA
4. Onboard Sound wäre OK.
5. SLI für Grafik wäre schön (geht das mit Win2K ?), ansonsten ohne SLI
Danke Euch
Doc
SLI won't work with Microsoft Windows 2000
Nor will it, ever
By Fuad Abazovic
Mon May 16 2005, 12:35 inShare.0
WE LEARNED ONE more thing about Nvidia SLI drivers. Windows 2000 users may not like the fact that SLI won't work on this operating system. As a matter a fact it will never work on W2K. I don't think it's impossible to make it run but it would require too much engineering work and not many people use Windows 2000 anyway, presumably the argument goes.
It's odd that Nvidia says that its driver works under Windows 2000 and Windows XP but when you install SLI on Win2K you will simply fail to make it work. When asked, Nvidia said that there are no plans for Windows 2000 support unless it changes its mind.
It turns out that Nvidia SLI is a Windows XP marchitecture only and I wonder whether this dual card marchitecture work on new Windows 2003 server like operating systems. That's something to ponder.
However, Nvidia will always say that if you want to play you have to use Windows XP and that's it. Will ATI make its Multi rendering work on Win 2K? I highly doubt it. µ
The Inquirer (http://s.tt/15Pru)
