System Memory Controller
—One 64-bit wide DDR SDRAM data channel
Up to 2.0 GB of 266/333 MHz DDR SDRAM
—Bandwidth up to 2.7 GB/s (DDR333)
—64-Mb, 128-Mb, 256-Mb, and 512-Mb SDRAM
technologies
—Supports only x8 and x16 SDRAM devices with four
banks
—Unbuffered, unregistered 184-pin non-ECC DDR
SDRAM DIMMs only
—Two DDR DIMMs, single-sided and/or double-sided
—Does not support double-sided x16 DDR DIMMs
—JEDEC DDR DIMM specification configurations only
—Opportunistic refresh
—Up to 16, simultaneously open pages
—SPD (Serial Presence Detect) scheme for DIMM
detection
—Suspend-to-RAM support using CKE
—Selective Command-Per-Clock (selective CPC) accesses
http://www.intel.com/assets/pdf/datasheet/251924.pdf
Fazit: 2x1 GB ddr-pc2700 333Mhz
