[Sammelthread] DDR5 Info- & Laberthread 2023
DDR5 - Ein Überblick
DDR5 Tests & WWW Reviews
DDR5 Links & weiterführende Informationen
(@even.de)
(@Reous)
  • Preisvergleich: https://geizhals.de/?cat=ramddr3&xf=15903_DDR5
  • DRAM Hersteller:
    - Hynix : DDR5
    - Micron : DDR5
    - Nanya : DDR5
    - Samsung : DDR5
  • JEDEC DDR5 Standard: JESD79-5 (paywalled)
  • Informationen zu den DDR5 Timings und JEDEC Speed Bins: Insights into DDR5 Subtimings and Latencies @ AnandTech
  • Intel Extreme Memory Profile DDR5 Standard: Ver 3.0 (Microsite | XMP 3.0 - Certified Memory List)
  • SPD Fixing (ASUS Method): https://www.overclock.net/threads/corrupted-ddr5-spd-fix-tutorial.1795935/
  • OC Guides (general)
    1) https://www.tomshardware.com/how-to/overclock-ddr5-ram
    2) https://www.igorslab.de/wie-ueberta...r-richtig-basic-und-tutorial-fuer-das-ram-oc/ (für DDR4, enthält aber die Basics)
    3) https://github.com/integralfx/MemTestHelper/blob/oc-guide/DDR4 OC Guide.md (für DDR4, enthält aber die Basics)
  • OC Guides (AMD)
    1) https://www.overclock.net/threads/amd-hynix-ddr5-overclocking-guide.1801842/
    2) https://www.igorslab.de/amd-ryzen-7...m-praxistest-mit-benchmarks-und-empfehlungen/
    3) https://skatterbencher.com/2022/09/26/raphael-overclocking-whats-new/
  • OC Guides (Intel)
    1) https://skatterbencher.com/2021/11/04/alder-lake-overclocking-whats-new/
    2) https://vintologi.com/threads/ddr5-overclocking-nightmare.1229/
    3) https://www.overclockers.com/ddr5-overclocking-guide/
  • OC Guides (Video)
    1) Intel 13th Gen K series & DDR5 overclocking insights and demos @ ASUS
    2) Finding the timing limits of Samsung DDR5 16Gb B-die at 6400Mbps (Intel) @ AHOC
    3) Finding the limits of Hynix DDR5 at 6666Mbps (Intel) @ AHOC
    4) DDR5-6800 CL34 OC with just 1.45V on the MSI Z690 Unify X @ AHOC
    5) Easy memory timings for Hynix DDR5 with Ryzen 7000 @ AHOC
1) 2x16GB DDR4-4000 CL14 vs 2x16GB DDR6-6000 CL36
2) 2x8GB DDR4-3733 CL17 vs 2x8GB DDR5-5600 CL40 (Patriot Viper Steel vs Patriot Viper Venom)
3) 2x16GB DDR4-3600 CL18 vs 2x16GB DDR5-4800 CL40 vs 2x16GB DDR5-6000 CL36 vs 2x16GB DDR5-7200 CL34 (TeamGroup T-Force Delta RGB FF3D516G7200HC34ABK)
4) 4x8GB DDR4-4000 CL15 vs 2x16GB DDR5-7200 CL34 (G.SKILL Ripjaws V F4-4000C15Q-32GVK vs Trident Z5 RGB F5-7200J3445G16GX2-TZ5RK)
Hardwareluxx: Corsair Dominator Platinum RGB CMT32GX5M2B5200C38-PK1 | G.Skill Ripjaws S5 F5-5200U4040A16GX2-RS5W | Kingston Fury Beast KF552C40BBK2-32 (vs DDR4-3200/4000, Corsair Vengeance CMW32GX4M4C3600C18)
1) Corsair Dominator Platinum RGB CMT32GX5M2B5200C38 (vs Corsair Dominator Platinum RGB DDR4-3600 16-16-16 ???)
2) Corsair Vengeance CMK32GX5M2B5200C38 (vs ADATA XPG Gammix D20 AX4U36008G18A-DCBK20)
3) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs verschiedene Ripjwas V / Trident Z DDR4 in G1/G2)
4) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs Crucial Ballistix Max RGB BLM2K16G44C19U4BL)
5) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs G.SKILL Trident Z Royal F4-3600C16D-32GTR?)
6) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W (vs G.SKILL Trident Z Royal Elite F4-3600C14D-32GTESA)
7) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W vs G.SKILL F4-3600C14D-32GTESA @ i2hard.ru
8) Kingston Fury KF552C40BBK2-32 vs G.Skill Trident Z RGB F4-3600C16D-32GTZR @ Guru3d
9) Corsair Vengeance CMK64GX5M2A4400C36 vs Corsair Vengeance LPX CMK32GX4M4K4000C19 - Linux Performance @ Phoronix
10) G.SKILL Trident Z5 F5-6000U4040E16GX2-TZ5S (OC 6200 CL38) vs G.Skill Trident Z Neo F4-4000C16D-32GTZNA(?) @ CapframeX (mit AMD Vergleichswerten für 5900X & DDR4-3733 CL14)
Die ist eine verkürzte Schreibweise, mit der man sich auf einen bestimmten IC Typ bezieht.
Zusammensetzung (am Beispiel von H16M): DRAM Manufacturer (Hynix) | IC Denisity in Gbit (16Gbit) | Die Revision (M-Die)
Häufig verwendete Kürzel:
M16A - Micron 16Gbit A-Die
H16A - Hynix 16Gbit A-Die
H16M - Hynix 16Gbit M-Die
S16B - Samsung 16Gbit B-Die​
Die Kürzel können auch generationsübergreifend verwendet werden. Dabei wird die DDR-Generation vorangestellt. Beispiele:
4S8B = Samsung 8Gbit B-Die DDR4
4S16B = Samsung 16Gbit B-Die DDR4
5S16B = Samsung 16Gbit B-Die DDR5
CorsairG.SKILL
Ver3.43.01 = Micron 16Gbit A-Die (Q1 | Q2 | Q3)
Ver3.43.04 = Micron 16Gbit D-Eie (Q1)
Ver3.53.02 = Micron 24Gbit B-Die (Q1)
Ver4.43.13 / .02 = Samsung 16Gbit B-Die (Q1 | Q2 | Q3)
Ver5.43.01 = Hynix 16Gbit A-Die (Q1)
Ver5.43.13 = Hynix 16Gbit M-Die (Q1 | Q2 | Q3)
Ver5.53.13 = Hynix 24Gbit M-Die (Q1)
Lot Code
-88... = 8Gbit Downbin eines 16Gbit ICs, -8821A entspricht also einem 5H16A Downbin
-S810B = Samsung 16Gbit B-Die (Q1)
-S82*A = Hynix 16Gbit A-Die (Q1)
-S82*M = Hynix 16Gbit M-Die (Q1)
-S83*A = Micron 16Gbit A-Die (Q1)
-R82*M = Hynix 24Gbit M-Die (Q1)
-R83*A = Micron 24Gbit A-Die
KingstonPatriot
Production Code: ETM[M][08]A2104
H - Hynix
K - Chips wurden relabeled / ICs have been relabeled by Kingston
M - Micron (Spectek)
N - Nanya
S - Samsung
04/08/16 = Anzahl der auf einem Modul verbauten DRAM Chips.
Daraus ergibt sich auch die Organisation:
04 = 1Rx16
08 = 1Rx8
16 = 2Rx8
Nach aktuellem Stand hat sich Patriot offenbar dazu entschieden den seitlichen Produktionscode auf dem Label zu entfernen. Die bisher abgelichteten Kits hatten statt dessen an dieser Stelle alle nur noch fünf Sternchen (*****). Damit ist also an Hand des Labels keine Identifikation der ICs mehr möglich.
CrucialMicron
Zusammensetzung: SKU.Suffix
SKU: CT16G56C46U5 - Part Number des Moduls
( Hier eines von zwei Modulen aus einem Kit vom Typ CT2K16G56C48U5. )
Suffix: .M8G1
M - DRAM Manufacturer: (M)icron, (H)ynix, (K/S)amsung
8 - Anzahl ICs: 4 = 1Rx16, 8 = 1Rx8, 16 = 2Rx8
G - Die Revision: A (Rev A / "A-Die"), G (Rev G / "G-Die")
1 - PCB Revision
Die Speicherdichte lässt sich aus der Kapazität des Moduls und der Anzahl der DRAM Chips ableiten. Ein 16GB Modul in 1Rx8 und ein 32GB Modul in 2Rx8 Organisation sind beispielweise aus 16Gbit ICs produziert.
Speed Bin & Die Revision
Beispiel 1 (32GB UDIMM): MTC20C2085S1EC56BG1R = Rev G (DDR5-5600)
Beispiel 2 (32GB UDIMM): MTC20C2085S1EC48BA1R = Rev A (DDR5-4800)
Beispiel 3 (16GB UDIMM): MTC10C1084S1EC48BA1R = Rev A (DDR5-4800)
Der DRAM Hersteller ist üblicherweise in das SPD programmiert und wird von CPU-Z (SPD Tab) angezeigt. Wenn die Die Revision programmiert ist, kann sie per Software z.B. mit HWinfo (ab 7.26) oder Thaiphoon Burner* ausgelesen werden. Ist sie nicht hinterlegt, wird im entsprechenden Feld je nach Programm nur "0.0" oder "N/A" (not available) angezeigt.
corsair-ddr5-7200-cl34-hwinfo_1920px.png HWInfo64_DRAM_Stepping_7.40.5000 [2].png
*Die Verwendung erfordert unter Windows 11 zur Zeit die temporäre Deaktivierung der Windows Kernisolierung und Speicherintegrität (02/2023).
So, hier noch die versprochene Excel-Tabelle. Einfach den gewünschten Takt eingeben, und die Primarys, dann rechnet es die anderen aus. So mal als Hilfe. Kann auch gerne in den Startpost angepinnt werden.
Download Im Anhang.
Vereinfachte Übertaktungstabelle DDR5 (erste Version):
Hinweise
tCL - beliebig, aus dem Intervall 22 bis 66
tWR - ein Vielfaches von 6, aus dem Intervall 48 bis 96
tRTP - gültige Werte 12, 14, 15, 17, 18, 20, 21, 23, 24
CCDL - beliebig, aus dem Intervall 8 bis 16
CCDLWR - entspricht dem Doppelten von CCDL, ergo nur gerade Zahlen aus dem Intervall 16 bis 32
Micron DDR5 Table.png DDR5_Performance_Preview.png ddr5_micron_infographic.png Intel XMP 3.0 Standard.jpg GSK_DDR5_Lot_Code_RCR.jpg Kingston_DDR5_Lot_Code_RCR.jpg AMD-Roadmap-Leak.jpg Intel Alder Lake Mobile Lineup.jpg PDF Final Intel ISC June 18 Deck for Press Briefing -page-017.jpg JEDEC_DDR5_10.png JEDEC_DDR5_RDIMM_12.png JEDEC_DDR5_09.png
Einige Informationen noch vorläufig. Bitte tagged mich für Korrekturen/Ergänzungen zum Startbeitrag und verlinkt immer auch die originale Quelle. Danke!
  • simpletable2forDDR5.zip
Sagt mal, wie zuverlässig ist der Windows Speicher Test bezüglich RAM-Stabilität?
Die haben doch den Schuss nicht gehört...
Ich bin zwar schon verzweifelt was die Bestellung jeglicher DDR5 Speicher angeht,
da ich seit Wochen auf der Lauer bin um überhaupt einen Riegel in die Finger zu bekommen,
aber auch wieder nicht so heftig dass ich den doppelten bis vierfachen Preis bezahle. 😂
Ich hab echt alles hier für den neuen PC, nur der Arbeitsspeicher fehlt noch da ich ein DDR5 Board gewählt habe. 😢
Wenn das so weitergeht wird das dieses Jahr nichts mehr sollte die Knappheit weiter bestehen.
nimm Memtest5 oder Karhu für Speichertest ;-)
dann waren meine 6000C36 für 691,- von Mercateo ja nicht mehr ganz so arg überteuert wenn das so weiter geht :LOL:
Hier das Gleiche. Die Kartons meines neuen Mainboards und der CPU setzen schon Staub an. Alternate meint, dass sie nächste Woche meinen G-Skill RAM bekommen würden. Ich glaube das erst, wenn die Trackingnummer da ist. :ROFLMAO:
Ich wär für den Anfang bis ich was besseres bekomme auch schon mit einem 8 GB Riegel zufrieden,
nur um endlich vom alten PC-System wegzukommen, meine Wa-Kü macht glaub ich nicht mehr lange mit,
die hört sich an wie ne Aquariumpumpe :ROFLMAO:
Bei den G.Skills letztens hat das System sofort die Bestellmöglichkeit eingestellt wo die zwei verfügbaren Kits raus waren. Hier ist aber scheinbar keine Lagerware sondern auch "In Kürze erwartet" sprich in Zulauf ohne Zahlen. Jetzt zu bestellen führt mMn zu 90% auf ein Storno, aber der Versuch mit PP / KK kostet ja nichts
Hab die Gskills 6000cl40 Mittwoch bei Computerunivers bestellt und die sind versandt worden………
Oh ja, ich fege auch schon jeden Tag den Staub von den Kartons. Wirklich nervig für uns "DDR5-RAM-Losen".:cautious:
Nicht sehr, da gibt es bessere Alternativen. Schau mal im Sticky vorbei:
Den hatte ich hier anfangs selbst schon mal verlinkt. Der Download sollte sich hoffentlich über den Micron-Verweis im Startbeitrag finden lassen?
In der DDR4 Übersicht hatte ich versucht eine Liste der Datenblätter zu pflegen, aber die Links sind teilweise schneller gestorben als Eintagsfliegen 😅
Wie im wirklichen Leben: die einen haben viel, die anderen nix. 😂😂😂😂
Ja nur, warum bunkern? Gibt ja keine Drops wie bei den Grakas.
Aber anscheinend kann man trotzdem scalpen, die Ebay Angebote sind immer gleich wieder weg. Es nervt wirklich immer mehr. Da es auch bei den (µATX) auch noch mau aussieht, hab ich noch nicht so den Druck, aber insgesamt einfach Scheisse.
Bestell Brett und CPU erst, wenn ich den RAM in der Hand hab. Wegen dem Staubwischen. 😂
So mache ich es auch. Wahrscheinlich geht das Scalpen dann da auch los.
Die Boards verstauben im Lager und fallen im Preis. Und die Hersteller bringen brauchbare BIOS-Versionen raus.
einfach ein Trauerspiel mit dem RAM
es ödet mich an
es ödet mich an
ja, hier (in der Schweiz) G.Skill 2x16 5600 = aktuell ca. 850 CHF und Termin nicht bekannt, 6000er noch nicht mal Vorbestellbar, lagen mal auch bei 900CHF. Haben doch einen Dachschaden :wall:
Mal positive Nachrichten: Mein bestellter G-Skill F5-5600U3636C16GX2-TZ5RK wurde gerade von Alternate versandt. 8-)
Bei mir auch !
Bestellt: 08.11. (kein Express :fresse2:)
366,99€
Gerade gesehen, dass mein RAM auch versandt wurde von Alternate. 6000 / CL36
630 Euro o_Oo_O Der Preisaufschlag zu den 5600 hat dann am Ende den Braten auch nicht mehr fett gemacht…
Hat jemand eine Empfehlung für ein Board? Scheint ja Probleme mit den XMP Profilen zu geben. Ich hatte da an das Aorus Pro gedacht, da es preislich relativ attraktiv ist.
Das Gigabyte Z690 Aorus Pro liegt bei mir auf dem Tisch und wartet auf den versendeten RAM. Macht einen sehr wertigen Eindruck. Viel mehr kann ich ohne RAM noch nicht dazu sagen.
Der G-Skill DDR5-6000 RAM steht aber nicht auf der Kompatibilitätsliste für das Board, daher müsstest du testen, ob er damit auch stabil läuft.
Schaut auf jeden Fall auf der Seite des RAM Herstellers wegen QVL. Gigabyte ist da eh ein Lügenverein
Da muss ich wohl die bittere Pille schlucken und doch zur Sicherheit den MSI Carbon nehmen. Das Force Mainbord ist zwar preislich attraktiver aber leider weiß. Meine restlichen Komponenten sind schwarz :fresse:
Achtung❗❗❗
das ist keine Garantie und es gibt aktuell z.B. bei ASUS Mainboards vermehrt Probleme mit Samsung Kits.
G.skill Speicher auf Asus Z690 Mainboards sind z.B. auf der Herstellerseite ist der Ram in der QVL für die Boards, bei Asus wird er nicht in der QVL geführt und es gibt auch aktuell bei vielen Probleme das die Samsung Speicher nicht stabil laufen.
Gerade Versandbestätigung von Alternate bekommen für 16GB ADATA RAM (übergangsweise bis ich an besseren komme)! Kann dann endlich meinen PC zusammenbauen :love:
es ödet mich an
ich krieg hoffentlich bald neue von @SH :P falls du bis dahin nix findest kann ich dir meine corsair 5200 cl38 zum einkaufspreis zukommen lassen
  • Danke
Reaktionen: SH
