Booten von XP über ISCSI
herrhannes
Hallo Leute,
ich habe ein doofes Problem:
Ich versuche XP nach dem Tutorial von etherboot.org über ISCI zu starten,
die da beschriebenen Schritte habe ich alle durchgeführt, inkl. der Installation von sanbootconf.
Nur will das Ding nicht booten.
Windows im Debugmodus spuckt Folgendes aus:
Waiting to reconnect...
Connected to Windows XP 2600 x86 compatible target at (Sun Apr 5 00:21:56.882 2009 (GMT+2)), ptr64 FALSE
Kernel Debugger connection established.
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
*** ERROR: Symbol file could not be found. Defaulted to export symbols for ntoskrnl.exe -
Windows XP Kernel Version 2600 UP Free x86 compatible
Built by: 2600.xpsp_sp2_rtm.040803-2158
Machine Name:
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055ab20
System Uptime: not available
Break instruction exception - code 80000003 (first chance)
nt!DbgBreakPoint:
804e3b14 cc int 3
kd> g
iSCSI Boot Parameter Driver initialising
Found iBFT at 9cb40 OEM ID "FENSYS" OEM table ID "gPXE"
Found iBFT Initiator 0:
Flags = 0x3, valid, boot selected
iSNS = 0.0.0.0
SLP = 0.0.0.0
Radius = 0.0.0.0, 0.0.0.0
Name = iqn.2000-09.org.etherboot:UNKNOWN
Found iBFT NIC 0:
IP = 192.168.0.201/24
Origin = 0
Gateway = 192.168.0.111
DNS = 192.168.0.111, 0.0.0.0
DHCP = 0.0.0.0
VLAN = 0000
MAC = 00:15:58:65:98:c1
PCI = 00:14.0
Hostname =
Found iBFT target 0:
IP = 192.168.0.27
Port = 3260
LUN = 0000-0000-0000-0000
CHAP type = 0 (None)
NIC = 0
Name = iqn.2009-04.local:iscsi
CHAP name =
CHAP secret =
Reverse CHAP name =
Reverse CHAP secret =
iSCSI Boot Parameter Driver initialisation complete
iSCSI boot parameters requested
Found iSCSI Boot Parameters at 85F9B080, attempting iSCSI boot
Allocating the Boot Connection Pool of size 30
Allocating Connection Pool 85F93610
Allocating the Boot Connection Pool entry 0 SUCCESS
Allocating the Boot Connection Pool entry 1 SUCCESS
Allocating the Boot Connection Pool entry 2 SUCCESS
Allocating the Boot Connection Pool entry 3 SUCCESS
Allocating the Boot Connection Pool entry 4 SUCCESS
Allocating the Boot Connection Pool entry 5 SUCCESS
Allocating the Boot Connection Pool entry 6 SUCCESS
Allocating the Boot Connection Pool entry 7 SUCCESS
Allocating the Boot Connection Pool entry 8 SUCCESS
Allocating the Boot Connection Pool entry 9 SUCCESS
Allocating the Boot Connection Pool entry 10 SUCCESS
Allocating the Boot Connection Pool entry 11 SUCCESS
Allocating the Boot Connection Pool entry 12 SUCCESS
Allocating the Boot Connection Pool entry 13 SUCCESS
Allocating the Boot Connection Pool entry 14 SUCCESS
Allocating the Boot Connection Pool entry 15 SUCCESS
Allocating the Boot Connection Pool entry 16 SUCCESS
Allocating the Boot Connection Pool entry 17 SUCCESS
Allocating the Boot Connection Pool entry 18 SUCCESS
Allocating the Boot Connection Pool entry 19 SUCCESS
Allocating the Boot Connection Pool entry 20 SUCCESS
Allocating the Boot Connection Pool entry 21 SUCCESS
Allocating the Boot Connection Pool entry 22 SUCCESS
Allocating the Boot Connection Pool entry 23 SUCCESS
Allocating the Boot Connection Pool entry 24 SUCCESS
Allocating the Boot Connection Pool entry 25 SUCCESS
Allocating the Boot Connection Pool entry 26 SUCCESS
Allocating the Boot Connection Pool entry 27 SUCCESS
Allocating the Boot Connection Pool entry 28 SUCCESS
Allocating the Boot Connection Pool entry 29 SUCCESS
Waiting 60 seconds for boot disk
iSpSystemWorkerThread: Entering
iSpSystemWorkerThread: Coming out of wait
iSpSystemWorkerThread: Start Logon Completion Thread 85FDFB70
iSpSystemWorkerThread: After Logon Completion Thread
iSpSystemWorkerThread: Reinstate Failed Connection 85FDFB70
Using Connection 85EDE008 index = 0 for Boot Session 85FA5000
Queue a WorkItem to create connections for Boot Session 85FA5000
iSpBootConnectionPoolworker: Entering Session = 85FA5000
iSpBootConnectionPoolworker: Exit Session = 85FA5000
iSpSystemWorkerThread: Failed Connection finish
iSpSystemWorkerThread: Start Logon Completion Thread 85EDE008
iSpSystemWorkerThread: Reinstate Failed Connection 85EDE008
Using Connection 85FB5008 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85FB5008
iSpSystemWorkerThread: Reinstate Failed Connection 85FB5008
Using Connection 85F90008 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85F90008
iSpSystemWorkerThread: Reinstate Failed Connection 85F90008
Using Connection 85EDB008 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85EDB008
iSpSystemWorkerThread: Reinstate Failed Connection 85EDB008
Using Connection 85EDBB70 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85EDBB70
iSpSystemWorkerThread: Reinstate Failed Connection 85EDBB70
Using Connection 85FEF008 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85FEF008
iSpSystemWorkerThread: Reinstate Failed Connection 85FEF008
Using Connection 85FEFB70 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85FEFB70
iSpSystemWorkerThread: Reinstate Failed Connection 85FEFB70
Using Connection 85FEF5B0 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85FEF5B0
iSpSystemWorkerThread: Reinstate Failed Connection 85FEF5B0
Using Connection 8600AA48 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 8600AA48
iSpSystemWorkerThread: Reinstate Failed Connection 8600AA48
Using Connection 8600A318 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 8600A318
iSpSystemWorkerThread: Reinstate Failed Connection 8600A318
Using Connection 85EFAB70 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85EFAB70
iSpSystemWorkerThread: Reinstate Failed Connection 85EFAB70
Using Connection 85EFA440 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85EFA440
iSpSystemWorkerThread: Reinstate Failed Connection 85EFA440
Using Connection 85F4C008 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85F4C008
iSpSystemWorkerThread: Reinstate Failed Connection 85F4C008
Using Connection 85F4C8D8 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85F4C8D8
iSpSystemWorkerThread: Reinstate Failed Connection 85F4C8D8
Using Connection 85FB4008 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85FB4008
iSpSystemWorkerThread: Reinstate Failed Connection 85FB4008
Using Connection 85FB4A48 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85FB4A48
iSpSystemWorkerThread: Reinstate Failed Connection 85FB4A48
Using Connection 85F8F008 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85F8F008
iSpSystemWorkerThread: Reinstate Failed Connection 85F8F008
Using Connection 85F8FB70 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85F8FB70
iSpSystemWorkerThread: Reinstate Failed Connection 85F8FB70
Using Connection 85EDA008 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85EDA008
iSpSystemWorkerThread: Reinstate Failed Connection 85EDA008
Using Connection 85EDAB70 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85EDAB70
iSpSystemWorkerThread: Reinstate Failed Connection 85EDAB70
Using Connection 85EDA5B0 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85EDA5B0
iSpSystemWorkerThread: Reinstate Failed Connection 85EDA5B0
Using Connection 85FEEA48 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85FEEA48
iSpSystemWorkerThread: Reinstate Failed Connection 85FEEA48
Using Connection 85FEE318 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85FEE318
iSpSystemWorkerThread: Reinstate Failed Connection 85FEE318
Using Connection 86009B70 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 86009B70
iSpSystemWorkerThread: Reinstate Failed Connection 86009B70
Using Connection 86009440 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 86009440
iSpSystemWorkerThread: Reinstate Failed Connection 86009440
Using Connection 85EF9008 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85EF9008
iSpSystemWorkerThread: Reinstate Failed Connection 85EF9008
Using Connection 85EF98D8 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85EF98D8
iSpSystemWorkerThread: Reinstate Failed Connection 85EF98D8
Using Connection 85F4B008 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85F4B008
iSpSystemWorkerThread: Reinstate Failed Connection 85F4B008
Using Connection 85F4BA48 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85F4BA48
iSpSystemWorkerThread: Reinstate Failed Connection 85F4BA48
Using Connection 85FB3008 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85FB3008
iSpSystemWorkerThread: Reinstate Failed Connection 85FB3008
Using Connection 85FB3B70 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85FB3B70
iSpSystemWorkerThread: Reinstate Failed Connection 85FB3B70
Using Connection 85F8E008 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85F8E008
iSpSystemWorkerThread: Reinstate Failed Connection 85F8E008
Using Connection 85F8EB70 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85F8EB70
iSpSystemWorkerThread: Reinstate Failed Connection 85F8EB70
Using Connection 85ED9008 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85ED9008
iSpSystemWorkerThread: Reinstate Failed Connection 85ED9008
Using Connection 85ED9B70 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85ED9B70
iSpSystemWorkerThread: Reinstate Failed Connection 85ED9B70
Using Connection 85ED95B0 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85ED95B0
iSpSystemWorkerThread: Reinstate Failed Connection 85ED95B0
Using Connection 85FEDA48 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85FEDA48
iSpSystemWorkerThread: Reinstate Failed Connection 85FEDA48
Using Connection 85FED318 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85FED318
iSpSystemWorkerThread: Reinstate Failed Connection 85FED318
Using Connection 86008B70 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 86008B70
iSpSystemWorkerThread: Reinstate Failed Connection 86008B70
Using Connection 86008440 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 86008440
iSpSystemWorkerThread: Reinstate Failed Connection 86008440
Using Connection 85EF8008 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85EF8008
iSpSystemWorkerThread: Reinstate Failed Connection 85EF8008
Using Connection 85EF88D8 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85EF88D8
iSpSystemWorkerThread: Reinstate Failed Connection 85EF88D8
Using Connection 85F4A008 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85F4A008
iSpSystemWorkerThread: Reinstate Failed Connection 85F4A008
Using Connection 85F4BB70 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85F4BB70
iSpSystemWorkerThread: Reinstate Failed Connection 85F4BB70
Using Connection 85F4AA48 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85F4AA48
iSpSystemWorkerThread: Reinstate Failed Connection 85F4AA48
Using Connection 85FEF6D8 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85FEF6D8
Timeout waiting for Disk to arrive.......
Delay 10 seconds for Disk to arrive.......
iSpSystemWorkerThread: Reinstate Failed Connection 85FEF6D8
Using Connection 85EDAA48 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85EDAA48
iSpSystemWorkerThread: Reinstate Failed Connection 85EDAA48
Using Connection 85FB4B70 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85FB4B70
iSpSystemWorkerThread: Reinstate Failed Connection 85FB4B70
Using Connection 85FB46D8 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85FB46D8
iSpSystemWorkerThread: Reinstate Failed Connection 85FB46D8
Using Connection 85FDF008 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85FDF008
iSpSystemWorkerThread: Reinstate Failed Connection 85FDF008
Using Connection 85EDB6D8 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85EDB6D8
iSpSystemWorkerThread: Reinstate Failed Connection 85EDB6D8
Using Connection 85F4CB70 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85F4CB70
iSpSystemWorkerThread: Reinstate Failed Connection 85F4CB70
Using Connection 85F8F6D8 index = 0 for Boot Session 85FA5000
iSpSystemWorkerThread: Start Logon Completion Thread 85F8F6D8
Delay for Disk Complete, continue with boot
ISCSI Boot Status 0, (0, 0, 0, 0)
StartIO: No Device for 85FA5000 (a0)
StartIO: No Device for 85FA5000 (12)
*** Fatal System Error: 0x0000007b
(0xF789E528,0xC0000034,0x00000000,0x00000000)
A fatal system error has occurred.
Debugger entered on first try; Bugcheck callbacks have not been invoked.
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 7B, {f789e528, c0000034, 0, 0}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
Probably caused by : ntoskrnl.exe ( nt!KeDeregisterBugCheckReasonCallback+6c7 )
Followup: MachineOwner
nt!DbgBreakPointWithStatus+0x4:
804e3b25 cc int 3
Ich hoffe mal, ich habe die Länge nicht übertrieben.
Aber es sieht ja schon einmal so aus, als hätte er sich mit dem ISCSI-Target verbunden und als fange er an zu laden, oder?
Was kann ich denn da noch weiteres testen, woran es liegen könnte?
Anscheinend sind ja alle wichtigen Treiber (Auch für ISCSI und LAN) geladen:
ModLoad: f7987000 f7988b80 kdcom.dll
ModLoad: f7897000 f789a000 BOOTVID.dll
ModLoad: f7357000 f7385180 ACPI.sys
ModLoad: f7989000 f798a100 WMILIB.SYS
ModLoad: f7346000 f7356a80 pci.sys
ModLoad: f7487000 f748fd80 isapnp.sys
ModLoad: f7a4f000 f7a4fd00 pciide.sys
ModLoad: f7707000 f770d200 PCIIDEX.SYS
ModLoad: f7497000 f74a1500 MountMgr.sys
ModLoad: f7327000 f7345d80 ftdisk.sys
ModLoad: f798b000 f798c700 dmload.sys
ModLoad: f7301000 f7326a00 dmio.sys
ModLoad: f770f000 f7713900 PartMgr.sys
ModLoad: f74a7000 f74b4200 VolSnap.sys
ModLoad: f72d4000 f7300a80 NDIS.sys
ModLoad: f74b7000 f74c4600 NVENETFD.sys
ModLoad: f71ea000 f72d3480 NVNRM.SYS
ModLoad: f71d3000 f71e9780 KSecDD.sys
ModLoad: f7717000 f771c580 iscsiboot.sys
ModLoad: f71c0000 f71d2400 ipsec.sys
ModLoad: f74c7000 f74cf900 msgpc.sys
ModLoad: f771f000 f7723880 TDI.SYS
ModLoad: f7168000 f71bfa80 tcpip.sys
ModLoad: f7157000 f7167e00 psched.sys
ModLoad: f713f000 f7156480 atapi.sys
ModLoad: f74d7000 f74dfe00 disk.sys
ModLoad: f74e7000 f74f3200 CLASSPNP.SYS
ModLoad: f7120000 f713e780 fltMgr.sys
ModLoad: f710e000 f711ff00 sr.sys
ModLoad: f7081000 f710d480 Ntfs.sys
ModLoad: f7066000 f7080580 Mup.sys
ModLoad: f7027000 f7066000 msiscsi.sys
ModLoad: f6ff1000 f7027000 iscsiprt.sys
ModLoad: f74f7000 f7502580 gagp30kx.sys
http://www.etherboot.org/wiki/sanboot/win7
Sehe ich das hier richtig, dass das Ganze mit einem nforce-onboard-LAN-Adapter gar nicht funktioniert oder gilt das bloß für Win7?
