[Sammelthread] ASUS Crosshair V Formula (AMD 990FX)
Crosshair V Formula
Spezifikationen
Prozessor / Sockel
  • AMD AM3+ FX™/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
  • Supports AM3+ 32 nm CPU
  • Supports CPU up to 8 cores
  • Supports CPU up to 140 W
  • AMD Cool 'n' Quiet™ Technology
Chipsatz
  • AMD 990FX/SB950
Arbeitsspeicher
  • 4 x DIMM, Max. 32GB, DDR3 2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 Hz ECC, Non-ECC, Un-buffered Memory Dual Channel Memory Architecture
Multi-GPU Support
  • Supports NVIDIA® 3-Way SLI™ Technology
  • Supports AMD 3-Way CrossFireX™ Technology
Erweiterungsschächte
  • 3 x PCIe 2.0 x16 (dual x16 or x16, x8, x8)
  • 1 x PCIe 2.0 x16 (x4 mode)
  • 1 x PCIe 2.0 x1
  • 1 x PCI
Storage
  • AMD SB950 controller:
    6 x SATA 6Gb/s port(s), red
    Support Raid 0, 1, 5, 10
  • ASMedia® ASM1061 controller:
    1 x SATA 6Gb/s port(s), red
    1 x eSATA 6Gb/s port(s), red
LAN
  • Intel®, 1 x Gigabit LAN Controller(s)
Audio
  • SupremeFX X-Fi 2 built-in 8-Channel High Definition Audio CODEC
    - Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
  • Audio Feature:
    - X-Fi® Xtreme Fidelity™
    - EAX® Advanced™ HD 5.0
    - THX® TruStudio PRO™
    - Creative ALchemy
    - Blu-ray audio layer Content Protection
    - Optical S/PDIF out port(s) at back panel
USB Ports
  • ASMedia® USB 3.0 controller:
    6 x USB 3.0 port(s) (4 at back panel, blue, 2 at mid-board)
    12 x USB 2.0 port(s) (8 at back panel, black+white, 4 at mid-board)
Übertaktung
  • ROG Connect:
    - RC Diagram
    - RC Remote
    - RC Poster
    - GPU TweakIt
  • Extreme Engine Digi+:
    - 8 + 2 phase power design
  • UEFI BIOS features:
    - ROG BIOS Print
    - GPU.DIMM Post
  • GameFirst
  • iROG
  • Extreme Tweaker
  • Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
Besondere Features
  • ASUS TPU:
    - CPU Level Up
  • Core Unlocker
  • ASUS Exclusive Features:
    - MemOK!
    - Ai Charger+
  • ASUS Quiet Thermal Solution:
    - ASUS Fan Xpert
  • ASUS EZ DIY:
    - ASUS Q-Shield
    - ASUS O.C. Profile
    - ASUS EZ Flash 2
    - ASUS MyLogo 3
  • ASUS Q-Design:
    - ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
    - ASUS Q-Connector
Anschlüsse (Rückseite)
  • 1 x PS/2 keyboard/mouse combo port(s)
  • 1 x eSATA 6Gb/s
  • 1 x LAN (RJ45) port(s)
  • 4 x USB 3.0
  • 8 x USB 2.0 (white port can be switched to ROG Connect)
  • 1 x Optical S/PDIF out
  • 6 x Audio jack(s)
  • 1 x Clear CMOS button(s)
Interne Anschlüsse
  • 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
  • 2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
  • 7 x SATA 6Gb/s connector(s)
  • 2 x CPU Fan connector(s)
  • 3 x Chassis Fan connector(s)
  • 3 x Optional Fan connector(s)
  • 1 x S/PDIF out header(s)
  • 1 x 24-pin EATX Power connector(s)
  • 1 x 8-pin ATX 12V Power connector(s)
  • 1 x 4-pin ATX 12V Power connector(s)
  • 1 x Front panel audio connector(s) (AAFP)
  • 1 x System panel(s)
  • 8 x ProbeIt Measurement Points
  • 3 x Thermal sensor connector(s)
  • 1 x En/Dis-able Clr CMOS header(s)
  • 1 x EZ Plug connector(s) (4-pin Molex power connector)
  • 1 x Power-on button(s)
  • 1 x Reset button(s)
  • 1 x CPU Level Up button(s)
  • 1 x ROG Connect switch(es)
  • 1 x Go Button(s)
BIOS
  • UEFI BIOS
Impressionen
Mainboard
Verpackung und Zubehör
UEFI BIOS
(Quelle aller Bilder: AwardFabrik)
BIOS Historie
  • Version 1703 [AKTUELLLSTE VERSION]
    - Improve system stability
    - Support new CPUs
  • Version 1605
    - Improve system stability.
    - Enhance compatibility with some USB devices.
  • Version 1503
  • Version 1402
  • Version 1301
  • Version 1102
  • Version 1003
    - Improve memory compatibility
  • Version 0903
    - Update CPU Level up function
  • Version 0813
    - Supports new CPUs
  • Version 0705
    - Fix USB 7/8 not work issue
    - Fix system may hang when use with Adaptec ASR-5805 Raid card
    - Add Spanish and Russian to BIOS steup.
    - Support new CPUs
  • Version 0506
  • Version 0404
    - First release Bios.
Reviews
Hartware.net
AwardFabrik
Planet 3DNow!
guru3d
Downloads
BIOS, Treiber und Ultilities
Nützliche Links
Liste der unterstützten Arbeitsspeicher
Liste der unterstützten CPUs
Geizhals
Kein Problem. Wird nachher auch noch um Bilder erweitert. Falls irgendwelche anderen Wünsche bestehen, einfach sagen. :d
Hi
habe das problem bei dem Board wenn ich meinen AMD 1090T OCe fängt der Sound an zu knacksen unter last kann das evtl. das Netzteil sein hab CPU über den Multi OCe könnt ihr mir helfen so läuft derr Rechner CPU läuft mit 19x200 also 3,8Ghz
Update das Problem ist wenn man. SPDIF nimmt beim OC fängt der Sound an zu stottern beim normal anschluss läuft alles hier sollte Asus noch mal was verbessern
So, nun auch in der AM3+ Übersicht und der alphabetischen Liste verlinkt :wink:
Ist's eigentlich normal, dass beim POST-Vorgang steht "Using PCIE Gen. 2 ... Can't find any device"? ^^
Mal eine Frage an die Kollegen hier mit dem Board:
Wie sieht das mit der Zuverlässigkeit aus? Hatte von euch schon jemand ein defektes? Ich las (lese) von einigen Leuten, dass das Board schon gut nach 1-2-3 Wochen den Geist aufgegeben hat (ok, vllt. von div. Wertungen sind das "nur" 10%, aber dennoch ja eine Quote).
Ich will mir, sobald der Bulli da ist, auf jeden Fall dieses Board holen. Könnt ihr eine Entwarnung aussprechen ;)?
Hmm habe das Board schon ne weile mit nen
955 zusammen am laufen auch übertaktet.Kann keine Probleme feststellen.
Bei mir läuft's mit meinem X6 1090T @3,6GHz seit knapp 3 Wochen und bisher auch einwandfrei.
ich habe es seit 22.07.2011 es ist hammer und min. genau so gut wie das IV!
das sind honks die pech hatten
hab sogar fast 1:1 alle einstellungen vom IV übernommen, nur CPU/NB nochmal runtergestellt :banana:
Hat schon jemand das 0813 BIOS getestet und konnte irgendwelche Unterschiede feststellen?
ne ist raus?
---------- Beitrag hinzugefügt um 18:07 ---------- Vorheriger Beitrag war um 18:03 ----------
keine infos auf der seite bezüglich änderungen nur das neue cpus unterstützt werden.
Eben, deswegen ja auch meine Frage. ^^
;) noch net probiert. ich werde mich aber leider von AMD trennen zu lange gewartet und zu früh das Board geholt.
welches ein traum ist!
man lernt halt immer dazu ne ;)
ALso ich hab / hatte das board auch.
meins ist momentan zur reparatur.
meine usb anschlüße haben nur noch sporadisch oder garnicht funktioniert und sind manchmal einfach ausgegangen.
lief aber erst 4-5 wochen problemlos..
ein kollege hats auch beim ihm ist alles top.
ansonsten super board!
Habe das neue Bios drauf.
In den Ram Einstellung gibt es ganz oben zwei neue Optionen.
Allerdings wenig interessant. Ich schau gleich mal wie die heißen.
Eins war auf jeden Fall für ein vordefeniertes 4GB Setting was mir den Ram aber auf CL7 schrauben will :fresse:
Hab allerdings auch 8GB.
Ansonsten keine änderungen.
Naja, immerhin keine negative Änderung. :P
Hab meines heute bekommen und hab mich bisher schon extrem darin verliebt.
So Kleinigkeiten wie n Bios mit Mauszeiger oder das ultraeinfache Freischalten von Kernen & Übertakten...
Aus meinem X3 720 mit 3x2,8Ghz ist innerhalb kürzester Zeit ein "X4 20" mit 4x3,2Ghz PrimeStable geworden *yay* :d
Ab 3,3Ghz spackt der 4te Kern rum, aber ich hab die Spannung auch nicht erhöht. Nur Multi auf 15 und die Mhz auf 213.
Dazu die Hammer Optik und die Gewissheit eines der Besten AM3(+) Boards derzeit zu haben... wunderbar.
ja ich habs getestet das neuje Bios die CPU liegt an stat 3200 jetz standart bei 3500.
Mann kann jetz entlich die Rahm speichertakt erhöhen wenn du das beim alten Bios gemacht hast dann ist das Win nicht aufgestartet ansonsten is mir nichtz mehr
aufegallen.
Hey hat hier jemand von euch die Version mit diese Thunderbolt Karte ?
Wenn ja, wozu ist diese extra Karte gut ? Taugt die was ?
Sind ja immerhin 70 Euronen unterschied zum Board ohne diese extra Karte...
(die Boards sind ja die gleichen, nur eben 1x mit Karte und 1x ohne oder ?)
aufegallen.
Ist schon mit dem alten Bios gegangen.....
---------- Beitrag hinzugefügt um 21:26 ---------- Vorheriger Beitrag war um 21:21 ----------
Hast du Thunderbold Endgeräte?, brauchst du die alternative Netzwerkkarte und Soundkarte die da oben ist? Wenn nein dann spar dir das Geld nachkaufen kannst du dir das noch immer kostet auch ca. 70€ .....
Hallo allerseits!
Hab gerade ein Problem mit dem Crosshair. Meine Config ist noch fast die gleiche wie in der Sig, außer Board, CPU und RAM: Crosshair V, X6 1090T, 8GB G.Skill 2133MHz, 2x GTX460 SLI. Als ich alles auf das neue Board umgebaut habe, lief alles ohne Probleme, zum ersten Mal das UEFI gestartet und Settings kontrolliert, alles im grünen Bereich - Win7 x64 gestartet, ging auch noch, aber nach Installation der Graka-Treiber 285.xx (WHQL & Beta getestet) bekomme ich Grafikfehler, sowohl in Windows als auch im UEFI (farbige Querstreifen). Der Chipsatz (NB) wird komischerweise sehr heiß (40mm FAN drüber und man kann den NB Kühler anfassen) - Worauf tipt Ihr - obere Graka oder MB?
Da ich eine Wakü habe, dachte ich, daß ich erst mal anfrage, bevor ich alles umbaue und mir evtl. die untere Graka zerschieße.
Prime läuft ohne Probs durch mit allen Thereads @ Stock.
Edit: Ur-BIOS: 0404 da ich nicht an den Button komme im BIOS, da mir nicht das ganze Fenster angezeigt wird.
mhm Fläsche mall Bios und hau dier dann denn 280.26 rauf und mach Bios Reset mall schaujen was dann Pasiert ich habe 3 Karten 2 im SLI und eine im Pysik x normal muss das reibungs loss laufen
karte raus und nur eine rein. bios flashen.
solltest du immernoch probleme haben andere karte rein und da testen.
solltest du immernoch probleme haben liegt es am board.
Danke für die Antworten!
Mit der 2.Graka hatte ich wieder das ganze Bild im BIOS sichtbar und konnte sogar bis in Windows booten, habe gleich das 0813 BIOS aufgespielt. Nach 10minuten die gleichen GrafikFehler. Habe schon mit MF gesprochen, Board geht heute zurück.
Das letzte ASUS-Board was ich hatte war das P5N32-SLI, da haben auf einmal die RAM 3Volt abbekommen, trotzdem ich nur 1,8V eingestellt hatte (waren DDR2). Nach all den Jahren dachte ich, man kann es wieder mal probieren mit ASUS. Aber irgendwie mag mich die Firma nicht.
