[table="width: 500, class: grid, align: left"]
[tr]
[td]Gaming Armor[/td]
[td]Power
[list]
[*]Hi-Density Power Connectors (24 pin and 8 pin)
[/list]
Memory
[list]
[*]15μ Gold Contact in DIMM Slots
[/list]
VGA Card
[list]
[*]15μ Gold Contact in VGA PCIe Slot (PCIE2)
[/list]
Internet
[list]
[*]Intel® LAN
[/list]
Cooling
[list]
[*]XXL Aluminum Alloy Heatsink
[/list]
Audio
[list]
[*]Creative Sound Blaster™ Cinema 3
[/list]
[/td]
[/tr]
[tr]
[td]Unique Feature[/td]
[td]ASRock USB 3.1
[list]
[*]ASRock USB 3.1 Type-A Port (10 Gb/s)
[*]ASRock USB 3.1 Type-C Port (10 Gb/s)
[/list]
ASRock Super Alloy
[list]
[*]Premium 45A Power Choke
[*]Nichicon 12K Black Caps (100% Japan made high quality conductive polymer capacitors)
[*]I/O Armor
[*]Matte Black PCB
[*]High Density Glass Fabric PCB
[*]2oz Copper PCB
[/list]
ASRock Steel Slots
ASRock Ultra M.2 (PCIe Gen3 x4 & SATA3)
ASRock Full Spike Protection (for all USB, Audio, LAN Ports)
ASRock Live Update & APP Shop
[/td]
[/tr]
[tr]
[td]CPU[/td]
[td]
[list]
[*]Supports AMD Socket AM4 A-Series APUs (Bristol Ridge) and Ryzen Series CPUs (Summit Ridge)
[*]IR Digital PWM
[*]12 Power Phase design
[*]Supports 95W Water Cooling
[/list]
[/td]
[/tr]
[tr]
[td]Chipset[/td]
[td]
[list]
[*]AMD Promontory X370
[/list]
[/td]
[/tr]
[tr]
[td]Memory[/td]
[td]
[list]
[*]Dual Channel DDR4 Memory Technology
[*]4 x DDR4 DIMM Slots
[*]AMD Ryzen series CPUs support DDR4 2933+(OC)2667/2400/2133 ECC & non-ECC, un-buffered memory*
[*]AMD 7th Gen A-Series APUs support DDR4 2400/2133 ECC & non-ECC, un-buffered memory*
[*]Max. capacity of system memory: 64GB**
[/list]
*Please refer to Memory Support List on ASRock's website for more information.
**Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS. For Windows® 64-bit OS with 64-bit CPU, there is no such limitation.
[/td]
[/tr]
[tr]
[td]BIOS[/td]
[td]
[list]
[*]128Mb AMI UEFI Legal BIOS with GUI support
[*]Supports "Plug and Play"
[*]ACPI 5.1 compliance wake up events
[*]Supports jumperfree
[*]SMBIOS 2.3 support
[*]CPU, VCORE_NB, DRAM, VPPM, PCH 1.05V, +1.8V, VDDP, PROM 2.5V, Voltage Multi-adjustment
[/list]
[/td]
[/tr]
[tr]
[td]Graphics[/td]
[td]
[list]
[*]Integrated AMD Radeon™ R-Series Graphics in A-series APU*
[*]DirectX 12, Pixel Shader 5.0
[*]Max. shared memory 2GB
[*]Supports HDMI with max. resolution up to 4K x 2K (4096x2160) @ 24Hz / (3840x2160) @ 30Hz
[*]Supports Auto Lip Sync, Deep Color (12bpc), xvYCC and HBR (High Bit Rate Audio) with HDMI Port (Compliant HDMI monitor is required)
[*]Supports HDCP with HDMI Port
[*]Supports Full HD 1080p Blu-ray (BD) playback with HDMI Port
[/list]
*Actual support may vary by CPU[/td]
[/tr]
[tr]
[td]Audio[/td]
[td]
[list]
[*]7.1 CH HD Audio with Content Protection (Realtek ALC1220 Audio Codec)
[*]Premium Blu-ray Audio support
[*]Supports Surge Protection
[*]Nichicon Fine Gold Series Audio Caps
[*]120dB SNR DAC with Differential Amplifier
[*]TI® NE5532 Premium Headset Amplifier for Front Panel Audio Connector (Supports up to 600 Ohm headsets)
[*]Pure Power-In
[*]Direct Drive Technology
[*]PCB Isolate Shielding
[*]Impedance Sensing on Line Out port
[*]Individual PCB Layers for R/L Audio Channel
[*]Gold Audio Jacks
[*]Supports Creative Sound Blaster™ Cinema 3
[/list]
[/td]
[/tr]
[tr]
[td]LAN[/td]
[td]
[list]
[*]Gigabit LAN 10/100/1000 Mb/s
[*]GigaLAN Intel® I211AT
[*]Supports Wake-On-LAN
[*]Supports Lightning/ESD Protection
[*]Supports Energy Efficient Ethernet 802.3az
[*]Supports PXE
[/list]
[/td]
[/tr]
[tr]
[td]Slots[/td]
[td]AMD Ryzen series CPUs
[list]
[*]2 x PCI Express 3.0 x16 Slots (single at x16 (PCIE2); dual at x8 (PCIE2) / x8 (PCIE4))*
[/list]
AMD 7th A-Series APUs
[list]
[*]1 x PCI Express 3.0 x16 Slot (single at x8 (PCIE2))*
[*]4 x PCI Express 2.0 x1 Slots
[*]Supports AMD Quad CrossFireX™ and CrossFireX™**
[*]Supports NVIDIA® Quad SLI™ and SLI™**
[*]1 x M.2 Socket (Key E), supports type 2230 WiFi/BT module
[/list]
*Supports NVMe SSD as boot disks
**This feature is only supported with Ryzen Series CPUs (Summit Ridge).
[/tr]
[tr]
[td]Storage[/td]
[td]
[list]
[*]6 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and Hot Plug
[*]1 x Ultra M.2 Socket (M2_1), supports M Key type 2230/2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s) (with Ryzen Series CPU) or Gen3 x2 (16 Gb/s) (with A-Series APU)*
[*]1 x M.2 Socket (M2_2), supports M Key type 2230/2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen2 x2 (10 Gb/s)*
[/list]
*Supports ASRock U.2 Kit Supports NVMe SSD as boot disks[/td]
[/tr]
[tr]
[td]Connector[/td]
[td]
[list]
[*]1 x COM Port Header
[*]1 x TPM Header
[*]1 x Power LED and Speaker Header
[*]1 x AMD Fan LED Header
[*]2 x RGB LED Headers*
[*]1 x CPU Fan Connector (4-pin)**
[*]1 x CPU Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)***
[*]2 x Chassis Fan Connectors (4-pin) (Smart Fan Speed Control)****
[*]1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)****
[*]1 x 24 pin ATX Power Connector (Hi-Density Power Connector)
[*]1 x 8 pin 12V Power Connector (Hi-Density Power Connector)
[*]1 x Front Panel Audio Connector
[*]1 x AMD LED Fan USB Header
[*]2 x USB 2.0 Headers (Support 4 USB 2.0 ports) (Supports ESD Protection)
[*]2 x USB 3.0 Headers (Support 4 USB 3.0 ports) (Supports ESD Protection)
[*]1 x Dr. Debug with LED
[/list]
*Supports up to 12V/3A, 36W LED Strip
**The CPU Fan Connector supports the CPU fan of maximum 1A (12W) fan power.
***The CPU Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
****The Chassis Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
[/td]
[/tr]
[tr]
[td]Rear Panel I/O[/td]
[td]
[list]
[*]2 x Antenna Ports
[*]1 x PS/2 Mouse Port
[*]1 x PS/2 Keyboard Port
[*]1 x HDMI Port
[*]1 x Optical SPDIF Out Port
[*]1 x USB 3.1 Type-A Port (10 Gb/s) (Supports ESD Protection)
[*]1 x USB 3.1 Type-C Port (10 Gb/s) (Supports ESD Protection)
[*]6 x USB 3.0 Ports (Supports ESD Protection)* 1 x Fatal1ty Mouse Port (USB 3.0) is included
[*]1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
[*]HD Audio Jacks: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone (Gold Audio Jacks)
[/list]
Software and UEFI[/td]
[/tr]
[tr]
[td]Software[/td]
[td]
[list]
[*]ASRock F-Stream
[*]ASRock RGB LED
[*]ASRock Key Master
[*]ASRock APP Charger
[*]ASRock XFast LAN*
[/list]
[/td]
[/tr]
[tr]
[td]UEFI[/td]
[td]
[list]
[*]ASRock Full HD UEFI
[*]ASRock Instant Flash
[*]ASRock Internet Flash
[*]ASRock Crashless BIOS
[*]ASRock Easy RAID Installer
[/list]
*These utilities can be downloaded from ASRock Live Update & APP Shop.[/td]
[/tr]
[tr]
[td]Support CD[/td]
[td]
[list]
[*]Drivers, Utilities, AntiVirus Software (Trial Version), Google Chrome Browser and Toolbar
[/list]
[/td]
[/tr]
[tr]
[td]Accessories[/td]
[td]
[list]
[*]Quick Installation Guide, Support CD, I/O Shield
[*]4 x SATA Data Cables
[*]1 x ASRock SLI_HB_Bridge_2S Card
[*]3 x Screws for M.2 Sockets
[/list]
[/td]
[/tr]
[tr]
[td]Hardware Monitor[/td]
[td]
[list]
[*]Temperature Sensing: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
[*]Fan Tachometer: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
[*]Quiet Fan (Auto adjust chassis fan speed by CPU temperature): CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
[*]Fan Multi-Speed Control: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
[*]Voltage monitoring: +12V, +5V, +3.3V, CPU Vcore, VCORE_NB, DRAM, PCH 1.05V, +1.8V, VDDP
[/list]
[/td]
[/tr]
[tr]
[td]Form Factor[/td]
[td]
[list]
[*]ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
[/list]
[/td]
[/tr]
[tr]
[td]OS[/td]
[td]
[list]
[*]Microsoft® Windows® 10 64-bit*
[/list]
*For the updated Windows® 10 driver, please visit ASRock's website for details.[/td]
[/tr]
[tr]
[td]Certifications[/td]
[td]
[list]
[*]FCC, CE
[*]ErP/EuP ready (ErP/EuP ready power supply is required)
[/list]
[/td]
[/tr]
[/table]
