> > > > Corsair stellt 550 MHz CAS2.5 DDR Module vor
DruckenE-Mail
Erstellt am: von
[url=http://www.corsairmemory.com]Corsair[/url] hat heute seine 550 MHz CAS2.5 DDR Module vorgestellt. Diese arbeiten mit Timings von 2.5-4-4-8 bei 550 MHz und 2-2-2-5 bei 400 MHz. Erhältlich sind sie als schwarze XMS Module (TwinX1024-4400C25) im Dual-Channel Kit mit 2x 512 MB oder als Platinum Module (TwinX1024-4400C25PT) ebenfalls im 2x 512 MB Dual-Channel Kit.
The ultra high clock speeds supported by these modules make them an ideal choice for extreme overclockers seeking the ultimate in performance. According to Corsair VP of Applications Engineering John Beekley, “we’ve tested these modules in our labs on a number of 875P, 865PE and 939-pin Athlon ™ 64 FX based motherboards with extremely impressive results.
Corsair Memory, Inc., a global leader in ultra-performance DDR memory modules for PC gamers and enthusiasts, today announced their fastest ever DDR memory module, a DDR550 module that supports very aggressive 2.5-4-4-8 latencies. These modules typically support 2-2-2-5 latencies at 400MHz clock speeds. The new parts are:
TwinX1024-4400C25 matched pair of 512MB, DDR550, 2.5-4-4-8, black XMS modules
TwinX1024-4400C25PT matched pair of 512MB, DDR550, 2.5-4-4-8, platinum XMS modules
Both these parts are available immediately from resellers worldwide, and are also available as individual 512MB modules. TwinX kits are tested as a matched pair at their rated specifications and packaged together immediately after passing test, guaranteeing that the customer receives a product that has been verified in the dual channel environment. These modules include Corsair’s classic black or platinum aluminum heat spreaders for improved heat dissipation.
The ultra high clock speeds supported by these modules make them an ideal choice for extreme overclockers seeking the ultimate in performance. According to Corsair VP of Applications Engineering John Beekley, "we’ve tested these modules in our labs on a number of 875P, 865PE and 939-pin Athlon ™ 64 FX based motherboards with extremely impressive results. This is the first time we’ve been able to run memory at 550 MHz on both Intel and AMD platforms… and at CAS 2.5!" Corsair R&D engineers have validated these modules on both Intel and AMD based platforms, but Corsair’s production test lines for these parts employ the Asus P4C800-E motherboard. "Moreover, we’ve driven our manufacturing cost down dramatically on this module compared to our earlier XMS4400 product, which will translate into surprisingly affordable street prices", Mr. Beekley added.
Detailed specifications on this product will be posted to Corsair's web site soon at
www.corsairmemory.com/corsair/xms.html. These modules can be purchased through Corsair’s authorized sales channels listed at www.corsairmemory.com/corsair/buy.html.
Social Links
Tags
es liegen noch keine Tags vor.
Zu diesem Artikel gibt es keinen Forumeintrag
RAM-Roundup: Sieben 16-GB-DDR4-Kits im Test
Logo von IMAGES/STORIES/NEWSBILDER/MNIEDERSTEBERG/ARTIKEL_2016/RAM-ROUNDUP/KLEVV_IM44GU48A30_5_LOGO
Seit der Einführung der Haswell-E-Plattform gibt es DDR4 im Consumer-Bereich, aber erst mit Skylake startete der Speicherstandard richtig durch. Seitdem sind bereits zahlreiche Monate vergangen und wie erwartet sind die Preise für den DDR4-Arbeitsspeicher in der Zwischenzeit ordentlich in den... [mehr]
Corsair bringt beleuchteten Arbeitsspeicher sowie neuen Lüfter und...
Logo von IMAGES/STORIES/LOGOS-2013/CORSAIR_LOGO
Corsair hat während der Computex 2016 gleich mehrere Neuheiten im Gepäck. Den Anfang machte die MSI GeForce GTX 1080 Sea Hawk. Der wassergekühlte 3D-Beschleuniger wird mit einer Kühllösung von Corsair bestückt und soll dadurch ein besonders hohes OC-Potential bieten können. Hierzu wird die... [mehr]
G.Skill bringt DDR4-Speicher Trident Z mit 4.266 MHz
Logo von GSKILL
G.Skill hat heute einen besonders schnellen DDR4-Arbeitsspeicher mit bis zu 4.266 MHz angekündigt. Der Speicher aus der bereits bekannten Trident-Z-Serie wird vom Hersteller als Extreme-Speed-Kit verkauft und soll vor allem mit einer hohen Geschwindigkeit punkten. Die Taktfrequenz von 4.266 MHz... [mehr]
Corsair stellt die schnellsten DDR4-Kits mit 128, 64 und 32 GB vor
Corsair hat neue Speicherkits der Vengeance-LPX-Reihe vorgestellt, die hohe Kapazität und Geschwindigkeit vereinen sollen. Die DDR4-Kits Vengeance LPX 128GB, 64GB und 32GB erreichen dabei Geschwindigkeiten von 3.600 MHz mit neuen XMP-2.0-Profilen. Allerdings gilt das nicht für die größten der... [mehr]
G.SKILL bringt DDR4-Speicher Trident Z mit 3.600 MHz und CL15
Logo von IMAGES/STORIES/LOGOS-2015/G
Speicherspezialist G.SKILL erweitert sein DDR4-Portfolio um neue Module der Trident-Z-Serie. Der Arbeitsspeicher wird als Kit, bestehend aus zwei 8-GB-Riegeln in den Handel kommen und damit eine Gesamtkapazität von 16 GB bereitstellen. Als Besonderheit nennt der Hersteller sowohl die... [mehr]
G.Skill Trident Z DDR4-Speicher erreicht über 5 GHz Taktfrequenz
Logo von GSKILL
G.Skill konnte einen neuen Rekord verbuchen. Laut dem Hersteller ist es einem Overclocker gelungen, einen DDR4-Speicher der Trident-Z-Serie auf 2.501 MHz zu übertakten. Somit lag die reale Taktfrequenz bei hohen 5001,2 MHz respektive DDR4-5000 und damit gleichzeitig nochmals deutlich über dem... [mehr]
