+ Antworten
Seite 1 von 13 1 2 3 4 5 11 ... LetzteLetzte
Ergebnis 1 bis 25 von 322
  1. #1
    Kapitän zur See Avatar von Xptweaker
    Registriert seit
    26.01.2003
    Österreich
    Standard Abit IP45-Pro / IP45-GT3/MAX / IX48 MAX (Intel P45 /X48)
    Erste Bilder der P45 / X48 Boards
    The model names are IP45-MAX, IP45 and IP43 Pro, and it gives away some information about what features the different models will have. Let's start from the bottom with the IP45, as this is a very basic P45 motherboard with a single x16 PCIe 2.0 slot, two PCIe x1 slots and three PCI slots. Around the back is a single PS/2 port, six USB 2.0 ports, a Gigabit Ethernet connector, 7.1-channel audio jacks with a coaxial S/PIDF out and a CMOS reset button.
    This board is limited to DDR2 800 and 1,066MHz memory, according to the specs, and it also has six SATA ports and headers for a further six USB 2.0 ports. Depending on the market, Abit has three additional models of this board, one with 10/100Mbit Ethernet, one with 5.1-channel sound and one with both. This is what is commonly known as cost down.
    Next up, we have the IP43 Pro, which appears to be a better motherboard than the IP45. It has the same slot layout and the same rear I/O layout, with the addition of an optical S/PDIF out. This board features Abit's micro Guru BIOS and silent OTES chipset cooling and supports DDR2 memory up to 1,200MHz.
    The IP45-MAX has a pair of x16 PCIe 2.0 slots, two PCIe x1 slots and two PCI slots. Around the back you'll find a PS/2 port, eight USB 2.0 ports, FireWire, two eSATA, 7.1-channel audio with optical and coaxial S/PDIF out, Gigabit Ethernet and a CMOS reset button. This board also has six SATA connectors, headers for a further four USB 2.0 ports and, of course, silent OTES chipset cooling and micro Guru BIOS. Finally, this board has four DDR3 memory slots with support for 1,600MHz DDR3 memory.
    Quelle : http://www.fudzilla.com/index.php?op...=7579&Itemid=1
    --------------------------------------- IP45 GT3 / MAX :---------------------------------------
    Abit IP45 GT3: Intel P45 DDR3-1600, ATi CrossfireX Support.
    The first abit's P45 motherboards that we saw is the IP45-MAX, which has four DDR3 DIMM slots (1600/1333MHz). The rest of the specifications look typical for a P45 board, with abit including only one Gigabit Ethernet unlike some other vendors. abit does include its own patented uGuru and Silent OTES technology. However, there is no exotic cooling solution for the board besides the now common heat pipe based cooler.
    Specs des IP45 MAX :
    ------------------------------------------- IP45 Pro : -------------------------------------------
    Similar to the MAX except for its use of DDR2 instead of DDR3 memory, the IP45 Pro has a more appealing color scheme in our opinion. The feature set remains however. LGA 775 , Intel® P45 , FSB 1600 , Dual DDR2 1200 , 2x PCI-E X16 (DualX8 CrossFire) , 2 x eSATA 3Gb/s , 6 x SATA 3Gb/s RAID , IEEE1394 , abit µGuru™ Technology , abit Silent OTES™ Technology ,100% Solid Solid Capacitors ,RoHS Compliant
    ------------------------------------------ IX48 MAX :------------------------------------------
    While it has been available already, let's not forget the X48 chipsets amidst all the P45/43 releases. Here's abit's IX48-MAX, which supports up to 4 DIMM of DDR3 1600 memory and has 2 PCIe x 16 Gen 2 slots but no CrossFireX (no dual x8). It does have abit's proprietary uGuru and OTES technologies.
    Quelle : http://www.hardwarezone.com/articles...cid=18&id=2576
    Geändert von Xptweaker (28.06.08 um 18:13 Uhr)
  2. #2
    Vizeadmiral Avatar von Enigma256
    Registriert seit
    27.08.2007
    Standard
    sexy
  3. #3
    Bootsmann Avatar von the_pi_man
    Registriert seit
    10.03.2004
    Köln
    • Systeminfo
      • Motherboard:
      • MSI P35 Neo2-FR
      • CPU:
      • Q6600 @ 3,15 GHz
      • Kühlung:
      • Wasser
      • Gehäuse:
      • Chieftec cs-601
      • RAM:
      • 8 GB PC2-1000
      • Storage:
      • 4 TB an Festplatten (WD,Samsung)
      • Monitor:
      • Dell UltraSharp 2007FP, 20.1"
      • Sound:
      • Audigy 2 ZS
      • Netzteil:
      • Enermax MODU82+ 525W
      • Betriebssystem:
      • Windows 7 Pro x64
      • Sonstiges:
      • Xtreamer mit 500GB
      • Notebook:
      • hab'sch nit
      • Photoequipment:
      • Nikon D200; 16-85mm VR
      • Handy:
      • Nokia E66
    Standard
    Was wohl das IP 45 Pro kosten wird....
  4. #4
    Registriert seit
    26.01.2003
    Österreich
    Themenstarter
    Standard
    denke mal etwas mehr als das IP35 pro 120- 130€ vielleicht ?
    mich interessiert der unterschied zwischen GT3 und Pro
    Geändert von Xptweaker (04.03.08 um 14:01 Uhr)
  5. #5
    Registriert seit
    10.03.2004
    Köln
    • Systeminfo
      • Motherboard:
      • MSI P35 Neo2-FR
      • CPU:
      • Q6600 @ 3,15 GHz
      • Kühlung:
      • Wasser
      • Gehäuse:
      • Chieftec cs-601
      • RAM:
      • 8 GB PC2-1000
      • Storage:
      • Monitor:
      • Sound:
      • Audigy 2 ZS
      • Netzteil:
      • Betriebssystem:
      • Windows 7 Pro x64
      • Sonstiges:
      • Notebook:
      • hab'sch nit
      • Photoequipment:
      • Handy:
      • Nokia E66
    Standard
    Ob dann die "alten" X38 Boards günstiger werden? Das Abit IX38-QuadGT würde mir ja auch gut gefallen. Die Hauptsache ist DDR-2 läuft drauf.
  6. #6
    Hauptgefreiter
    Registriert seit
    18.08.2004
    Standard
    gibts was neues zu den p45ern? Preise für mobos liefertermine etc??
  7. #7
    Hauptgefreiter Avatar von MAD-MIKE
    Registriert seit
    07.01.2006
    Standard
    hab mal bei Abit nachgefragt wann mit dem Abit ip45 zu rechnen ist. Als Aussage erhielt ich leider nur das es im 2. Quartal 08 auf den Markt kommen soll.
    Michl
    Q6600 @ 3,2 GHz
    Abit p35-E / G.skill 4GBPQ / Wakü
  8. #8
    Flottillenadmiral Avatar von Sonny C.
    Registriert seit
    03.08.2005
    Aachen Heimatort: Braunschweig
    Standard
    Das Max ist bei Alternate im Sortiment aufgenommen: http://www.alternate.de/html/product...l?artno=GPEB43
    Hinzugefügter Post:
    Ah, bei Geizhals nu auch: http://preisvergleich.hardwareluxx.de/deutschland/a286536.html ^
    Geändert von Sonny C. (09.04.08 um 20:45 Uhr) Grund: Antwort auf eigenen Beitrag innerhalb von 4 Stunden!
  9. #9
    Admiral Avatar von TopAce888
    Registriert seit
    16.04.2006
    • Systeminfo
      • Motherboard:
      • MSI P55-GD65
      • CPU:
      • Core i5 @ 3,6GHz
      • Kühlung:
      • Megahalems
      • Gehäuse:
      • Sharkoon Rebel 9 Pro
      • RAM:
      • 8GB G.Skill DDR3-1600 RipjawsX
      • Grafik:
      • Sapphire HD6850 @ 900/1150
      • Storage:
      • OCZ Vertex 2 120GB | Seagate Barracuda 7200.12 1TB
      • Monitor:
      • Iiyama ProLite E2207HDS-B1
      • Netzwerk:
      • TP-Link TL-WN821NC
      • Sound:
      • Creative Audigy 2 ZS
      • Netzteil:
      • BeQuiet StraightPower E7-480CM
      • Betriebssystem:
      • Windows 7
      • Notebook:
      • HP 625
      • Photoequipment:
      • Panasonic Lumix TZ8
    Standard
    Das IP45 Pro ist jetzt auch bei Alternate gelistet: http://www.alternate.de/html/product...ticleId=276229
    CPU: Core i5 750 @ 3600 MHz| CPU-Kühlung: Prolimatech Megahalems mit BeQuiet SilentWings 120 PWM | Mainboard: MSI P55-GD65 | RAM: 8GB G.Skill DDR3-1600 Ripjaws-X (8GBXL) | VGA: Sapphire HD6870 @ 950/1150 | GPU-Kühlung: Artic Twin Turbo 2 | HDD: OCZ Vertex 2 120GB | Seagate Barracuda 7200.12 1TB | Sound: onboard | Monitor: LG Flatron E2441T | Gehäuse: Sharkoon Rebel 9 Pro mit 120er BQ SilentWings USC | Netzteil: BeQuiet StraightPower E7-CM 480
    Verkaufe: Lancool PC-K9X | OCZ Vertex 2 3,5'' SSD 120 GB | Suche: Asrock P67 Transformer
  10. #10
    Kapitänleutnant Avatar von Larkin
    Registriert seit
    25.05.2008
    Regensburg/Bayern
    Standard
    Sehr geehrter Herr ,
    das IP45 Pro und IP45 sollte anfangs Juli im Laden verfügbar sein. Die DDR3 Variante (IP45 MAX) ein wenig später.
    Kind regards
    Mit freundlichem Gruss
    Wouter Simon
    Universal ABIT NL B.V.
    Jan van Riebeeckweg 15, 5928 LG Venlo, The Netherlands
    Irgendwie hat Abit nur einen Mann für deutschen Mail-Support. Seit 2002 antwortet mir immer der Wouter Simon
    Das IP45 is zu 99% gekauft wenns zum OC taugt.
    Geändert von Larkin (23.06.08 um 00:06 Uhr)
  11. #11
    Registriert seit
    16.04.2006
    • Systeminfo
      • Motherboard:
      • MSI P55-GD65
      • CPU:
      • Core i5 @ 3,6GHz
      • Kühlung:
      • Megahalems
      • Gehäuse:
      • RAM:
      • Grafik:
      • Storage:
      • Monitor:
      • Netzwerk:
      • Sound:
      • Netzteil:
      • Betriebssystem:
      • Windows 7
      • Notebook:
      • HP 625
      • Photoequipment:
    Standard
    Das taugt bestimmt zum OC. Was soll denn da schon schief gehen, wenn das IP35 Pro schon eine Granate war?
  12. #12
    Oberstabsgefreiter Avatar von MB4President
    Registriert seit
    30.09.2006
    LA
    Standard
    Hat jemand Infos darüber, wo der Unterschied zwischen der GT3 und der MAX Version liegt?
    Oder wurde da jetzt letzendlich bloß der Name geändert?
  13. #13
    Registriert seit
    26.01.2003
    Österreich
    Themenstarter
    Standard
    du meinst zwischen IP45 Pro und GT3 das MAX ist ein x48
  14. #14
    Registriert seit
    25.05.2008
    Regensburg/Bayern
    Standard
    IP 45 Pro: P45, DDR2
    GT3 : P45, DDR3
    Max : X48, DDR3
  15. #15
    Oberleutnant zur See
    Registriert seit
    08.05.2007
    Standard
    Oha, ein neuer Anwerter auf meiner Kaufliste, bin eh am überlegen soll ich mein Intel behalten und auf ein P45 uüdaten oder doch auf AMD wechseln, mhh
  16. #16
    Registriert seit
    25.05.2008
    Regensburg/Bayern
    Standard
    Also ich komm jetzt von AMD zu Intel. Aktuell überzeugt mich (leider) AMD nicht.
  17. #17
    Registriert seit
    30.09.2006
    LA
    Standard
    Nein ich meine das IP45 MAX
    http://www.forumdeluxx.de/forum/showthread.php?t=500899
  18. #18
    Registriert seit
    26.01.2003
    Österreich
    Themenstarter
    Standard
    so wie es aussieht wurde einfach aus IP45 GT3 .... IP45 MAX gemacht
  19. #19
    Registriert seit
    30.09.2006
    LA
    Standard
    Hatte ich mir auch schon gedacht, hab ich auch nix dagegen einzuwenden.
    Ich finde es furchtbar, wie einige Hersteller zig Versionen von einem Board rausbringen, wo jedes 2. im Prinzip dasselbe ist.
    Vor allem bei Asus und Gigabyte hat man überhaupt keinen Durchblick mehr
  20. #20
    Fregattenkapitän Avatar von andi92
    Registriert seit
    08.12.2007
    Im schönen Badnerland
    • Systeminfo
      • Motherboard:
      • ASUS Crosshair IV Formula
      • CPU:
      • AMD Phenom II X6 1100T
      • Gehäuse:
      • Lancool K7
      • RAM:
      • 4GB DDR3-1600 Corsair
      • Grafik:
      • MSI GTX580 OC
      • Storage:
      • Samsung 320GB + Samsung 500GB
      • Monitor:
      • ACER X203H
      • Sound:
      • Roccat Kave 5.1
      • Netzteil:
      • Silverstone Decathlon DA-800
      • Betriebssystem:
      • Windows 7 64-BIT
      • Photoequipment:
      • Panasonic DMC-G10K
      • Handy:
      • Nokia 6300
    Standard
    wann wird denn das IP45-Pro Board lieferbar sein? Weiss das schon jemand?
  21. #21
    Registriert seit
    16.04.2006
    • Systeminfo
      • Motherboard:
      • MSI P55-GD65
      • CPU:
      • Core i5 @ 3,6GHz
      • Kühlung:
      • Megahalems
      • Gehäuse:
      • RAM:
      • Grafik:
      • Storage:
      • Monitor:
      • Netzwerk:
      • Sound:
      • Netzteil:
      • Betriebssystem:
      • Windows 7
      • Notebook:
      • HP 625
      • Photoequipment:
    Standard
    Angeblich KW28 (das wäre dann die zweite Juli Woche)
  22. #22
    Leutnant zur See
    Registriert seit
    11.04.2006
    Königswinter
    Standard
    Sind bei www.snogard.de gelistet aber noch nicht verfügbar...
    IP45-Pro: 133,90
    IP45: 99,90
    IP43-Pro: 103,90
    IP43: 77,90
    Asrock Z77 Extreme4 / Xeon E3-1235 / Noctua DH-14 @ Scythe S-Flex / 8192MB Teamgroup Elite / Gigabyte GTX 570 OC / Xilence Interceptor / Extrememory XLR8 Plus Express 120GB + 2.5" Seagate 500GB / Creative X-Fi Titanium / Windows 7 Professional 64bit
  23. #23
    Registriert seit
    26.01.2003
    Österreich
    Themenstarter
  24. #24
    Registriert seit
    16.04.2006
    • Systeminfo
      • Motherboard:
      • MSI P55-GD65
      • CPU:
      • Core i5 @ 3,6GHz
      • Kühlung:
      • Megahalems
      • Gehäuse:
      • RAM:
      • Grafik:
      • Storage:
      • Monitor:
      • Netzwerk:
      • Sound:
      • Netzteil:
      • Betriebssystem:
      • Windows 7
      • Notebook:
      • HP 625
      • Photoequipment:
    Standard
    Naja, die Boards sind bei Mix und Alternate schon seit mehreren Tagen gelistet, aber natürlich nicht verfügbar, daran ändert auch jetzt nichts der Eintrag bei Geizhals. Es wird aber jetzt langsam Zeit, mittlerweile haben wir die zweite Juliwoche!
  25. #25
    Registriert seit
    26.01.2003
    Österreich
    Themenstarter
    Standard
    ja abit wird leider immer langsamer .... sei es mit neuen boards oder bios support ....
+ Antworten
Berechtigungen
  • Neue Themen erstellen: Nein
  • Themen beantworten: Nein
  • Anhänge hochladen: Nein
  • Beiträge bearbeiten: Nein
