Also ich bin das Problem losgeworden indem ich die FSB Spannung angehoben habe.
Prime-Fehlerfrei läuft das Ding aber noch nicht, ist echt ne harte Nuss.
Nicht über die hohe VCore wundern, der verbaute E8200 ist grottenschlecht...
Code:
Overclocking Einstellungen
Robust Graphics Booster [Auto]
CPU Clock Ratio [ 8 X]
*********************************** Clock Chip Control ************************************
CPU Host Clock Control [Enabled]
CPU Host Frequency(Mhz) [ 500]
PCI Express Frequency(Mhz) [100]
Advanced Clock Control [Press Enter]
****************************** DRAM Performance Control ******************************
Performance Enhance [Standard]
(G)MCH Frequency Latch [400MHz]
System Memory Multiplier (SPD) [2.00D]
DRAM Timing Selectable (SPD) [Manual]
CAS Latency Time 5 [5]
tRCD 5 [ 5]
tRP 5 [ 5]
tRAS 18 [ 15]
Advanced Timing Control [Press Enter]
****************************** Mother Board Voltage Control ****************************
CPU VCore 1.22500V [1.42500V]
CPU Termination 1.200V [1.320V]
CPU PLL 1.500V [Auto]
CPU Reference 0.760V [Auto]
CPU Reference2 0.800V [Auto]
MCH Core 1.100V [1.180V]
MCH Reference 0.760V [0.778V]
MCH/DRAM Reference 0.900V [0.940V]
ICH I/O 1.500V [Auto]
DRAM Voltage 1.800V [2.100V]
DRAM Termination 0.900V [0.940V]
Channel A Reference 0.900V [0.940V]
Channel B Reference 0.900V [0.940V]
