+ Antworten
Ergebnis 1 bis 10 von 10
  1. #1
    Gefreiter
    Registriert seit
    08.05.2009
    Standard distilled water help
    Hi forum members,
    I need your advise on this brand of distilled water:
    eurolub destilliertes wasser usefull in (nach vorschrift VDE 0510, DIN 57510):
    Autobatterien, autokuhler, dampfbugeleisen, kosm-ozondampfgerate, luftbefeuchter, pflanzenbespruhter, aquarien, laboranwendungen
    http://www.eurolub.de/systempflege.html
    And i can buy it here:
    http://www.it-service.be/webshop/pro...739b586798bee4
    Is this a good to go its a german brand and i have extreme dificulty to find distilled water here in Holland or if i find its demineralized water wich i dont want. But the store is specialised in watercooling for pc and they included this brand of distilled water. Il be using it together with a silver kill Coil wich i already have.
    Your toughts...
    Thanks in advance
    Geändert von Sniper1010 (05.11.09 um 23:27 Uhr)
  2. #2
    Vizeadmiral Avatar von fhantastic
    Registriert seit
    16.04.2008
    Uslar
    • Systeminfo
      • Motherboard:
      • MSI GD70
      • CPU:
      • PII 720BE
      • Systemname:
      • Black Hole
      • Kühlung:
      • Wasser
      • Gehäuse:
      • Lian Li
      • RAM:
      • Grafik:
      • XFX 4870 XXX
      • Storage:
      • Monitor:
      • P19-2
      • Betriebssystem:
      • Windows
      • Photoequipment:
      • Sony Alpha 380 + Kit Linse + Stativ
      • Handy:
      • nix besonderes :P
    Standard
    you can buy distilled water everywhere
    for example at the supermarket
  3. #3
    Bootsmann Avatar von faulwurf
    Registriert seit
    16.10.2007
    NRW
    • Systeminfo
      • Systemname:
      • Zockerkiste
      • Storage:
      • Genug
    Standard
    There is a difference between distilled water and other distilled water?
    In my opinion you can use whatever you want as long as it's called distilled water.
    But maybe i'm wrong...
    btw: last week i bought 5 liters from Aldi Süd for less than 2 euro.
    Gruss, Markus
    Intel i7-950 @ 4 GHz @ HK 3 LT | Gigabyte GA-X58A-UD7 @ WaKü | 6 GB Corsair Dominator 1600 CL8 | XFX 5870 @ AquagratiX | Corsair HX850W | X-FI Platinum | 7 x64 Professional @ OCZ Vertex 2 Ext. & Corsair Obsidian 800D
    Forum
  4. #4
    Registriert seit
    16.04.2008
    Uslar
    • Systeminfo
      • Motherboard:
      • MSI GD70
      • CPU:
      • PII 720BE
      • Systemname:
      • Black Hole
      • Kühlung:
      • Wasser
      • Gehäuse:
      • Lian Li
      • RAM:
      • Grafik:
      • XFX 4870 XXX
      • Storage:
      • Monitor:
      • P19-2
      • Betriebssystem:
      • Windows
      • Photoequipment:
      • Handy:
      • nix besonderes :P
    Standard
    no you are golden right ( hahaha my english is so f****** bad )
  5. #5
    Gefreiter
    Registriert seit
    08.05.2009
    Themenstarter
    Standard
    Thanks for the reply's,
    I tought i could buy it at any place, but thats not the case. Yes i went to the supermarket lots of them not one sold it except demineralized water. I went to other shops no succes either. Until i went to the online watercooling store wich they have the brand of distilled water i mentioned above. And wanted to know if that brand is good to go?
  6. #6
    Moderator Avatar von Schlingel_INV
    Registriert seit
    19.02.2006
    中国江苏省常州市/Germany Clausthal-Zellerfeld
    • Systeminfo
      • Motherboard:
      • MSI 890FXA-GD70
      • CPU:
      • AMD Phenom X4 B55 BE@3,2
      • Systemname:
      • 890FXA-GD70
      • Kühlung:
      • Full Water
      • Gehäuse:
      • LianLi PC-A7110B
      • RAM:
      • 4x2GB DDR3-1333
      • Grafik:
      • 9800GX2
      • Storage:
      • Corsair Force 60GB
      • Monitor:
      • Samsung 245B +
      • Netzwerk:
      • 10Gbit Infiniband HCA
      • Sound:
      • onboard
      • Netzteil:
      • Seasonic X-Series 560W
      • Betriebssystem:
      • Windows Server 2008 DC R2 x64
      • Sonstiges:
      • Dell Perc 6E + Dell Perc H700
      • Notebook:
      • Lenovo Thinkpad X60
      • Photoequipment:
      • Canon EOS 400D
      • Handy:
      • HTC HD2
    Standard
    most users here are using watercooling mixtures avaiable in watercooling-shops or like me demineralized water + BASF G40 (or equal). no need to get expensive destilled water. so there will be not too much experience with that product here
  7. #7
    Gefreiter
    Registriert seit
    08.05.2009
    Themenstarter
    Standard
    Thanks for the reply,
    No the water i mentioned is not expensive 2.00 euro a bottle 1 Liter, it states its plain distilled water, i sjust want to be sure its not some demineralized water sold as distilled water wich i saw to much in some stores here. Altough the water i mentioned is sold at a specialised store for watercooling for pc.
    The thing is there are places where i can buy distilled water but when i read the back of the bottle it reads clearly its demineralized water, wich in turn is not 100% distilled water for me distilled water means free of minerals and algea, bacteria. So its kind of misleading to put distilled water at the front of the bottle and when you read the back of the bottle it reads demineralized water. I also read that the best way to watercool your wc rig is with distilled water together with PT-nuke or Silver kill coil. Pre mixed water like for example feser pure water is just advertisment its almost the same as plain distilled water but you pay more for it. The use of dye colored water is not advised because it can glog your blocks with residue of the dye. And thus you need to clean your rig more often, (drop in temps) then when you use plain distilled water with silver coil or PT-nuke or some something similar.
    Geändert von Sniper1010 (06.11.09 um 00:38 Uhr)
  8. #8
    Registriert seit
    19.02.2006
    • Systeminfo
      • Motherboard:
      • MSI 890FXA-GD70
      • CPU:
      • Systemname:
      • 890FXA-GD70
      • Kühlung:
      • Full Water
      • Gehäuse:
      • LianLi PC-A7110B
      • RAM:
      • 4x2GB DDR3-1333
      • Grafik:
      • 9800GX2
      • Storage:
      • Monitor:
      • Samsung 245B +
      • Netzwerk:
      • Sound:
      • onboard
      • Netzteil:
      • Betriebssystem:
      • Sonstiges:
      • Notebook:
      • Photoequipment:
      • Canon EOS 400D
      • Handy:
      • HTC HD2
    Standard
    if ur using a laing pump u should add for example G40 to have a bit "oiling"-effect and a longer lifetime of your pump. just destilled water would be a bad choice. bacteria will be also "killed" or avoided due to G40 and the copper in ur rig. so no problems with that
    back to the question: if you need the really destilled water u can buy every brand. no difference. but I would say: there is no need for it
    Geändert von Schlingel_INV (06.11.09 um 00:42 Uhr)
  9. #9
    Leutnant zur See
    Registriert seit
    23.09.2002
    Doberlug-Kirchhain/Kornwestheim
    • Systeminfo
      • Motherboard:
      • ASUS P67 Sabertooth
      • CPU:
      • 2600k @ 4.4GHz
      • Kühlung:
      • Wasserkühlung
      • Gehäuse:
      • Chieftech
      • RAM:
      • 16GB DDR3 @ 1866MHz
      • Grafik:
      • GTX 570 SLI
      • Storage:
      • SSD: Crucial RealSSD C300 HDD: 2x500BG + 250GB
      • Monitor:
      • ASUS VK278Q
      • Sound:
      • ASUS Xonar D2X
      • Netzteil:
      • Corsair 850W
      • Betriebssystem:
      • Win7 Pro 64-bit
    Standard
    Hello Sniper.
    Don´t worry about using "just" demineralized water. It is nearly equal to distilled water, but much cheaper. The next advantage is, you can buy it in every supermarket.
    But you have to pay attention to one point. Don´t use demineralized water only. You should mix it with an additional liqiud for car cooling circuits. The best way to get this liqiud is, to ask for in a car dealership. It is called G40 and it is a product of the Volkswagen AG.
    Don´t hesitate to ask, if there are further questions.
    Es heißt Standard!!! Standart ist die Art zu stehen.
    Eigentlich kommt nicht von endlich
    __________________________________________________ __________________________Verkaufe Centerlautsprecher KEF iQ 2c
  10. #10
    Stabsgefreiter
    Registriert seit
    21.07.2006
    Pinneberg
    Standard
    As your rig (blocks, radiator, pumps) isn't perfectly clean when you fill in the water (laboratory conditions) it wont make any differences weather you use distilled or demineralized water.
    You need some additive, no matter what kind of water you chose. There will always be some dust in the rig making bacteria grow.
    And even if you can ensure that there're only copper waterblocks in your watercooling system, there will be different alloys ("Legierung") as pure copper is very difficult to machine. And brass in the fittings.
    Corrosion will be very slow and partly invisible to the eye...
    This system ran untouched for a very long time and the protection against corrosion from the additive ceased after some years:
    After some "cleaning"...
    Geändert von Power-user (06.11.09 um 13:21 Uhr)
Berechtigungen
  • Neue Themen erstellen: Nein
  • Themen beantworten: Nein
  • Anhänge hochladen: Nein
  • Beiträge bearbeiten: Nein
