+ Antworten
Ergebnis 1 bis 8 von 8
  1. #1
    Kapitänleutnant Avatar von dröfl
    Registriert seit
    18.12.2004
    Exclamation
    Zitat Zitat von D4rkCloud
    Ansonsten ist abzuwarten, ob Windows oder Intel das Problem in den griff kriegen.
    Selbst ist der Mann (man kanns ja mal versuchen):
    Warning: Serious problems might occur if you modify the registry incorrectly by using Registry Editor or by using another method. These problems might require that you reinstall your operating system. Microsoft cannot guarantee that these problems can be solved. Modify the registry at your own risk. To resolve this problem, add the EnIdleEndpointSupport entry to the USB registry key. To do this, follow these steps:
    1. Click Start, click Run, type regedit, and then click OK.
    2. Locate, and then click the following registry subkey:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\USB
    Note: If the USB subkey does not exist, create it. To do this, follow these steps:
    a. Select the Services key. On the Edit menu, point to New, and then click Key.
    b. Type USB in the New Key #1 box to name the new key "USB."
    3. Right-click USB, point to New, and then click DWORD Value.
    4. In the New Value #1 box that appears, type EnIdleEndpointSupport, and then press ENTER.
    5. Right-click EnIdleEndpointSupport, and then click Modify.
    6. In the Value data box, type 1, leave the Hexadecimal option selected, and then click OK.
    7. Quit Registry Editor.
    Resultat (usb 2.0 aktiv):
    Aber da das Asus A6JA eine integrierte Kamera hat und diese über usb 2.0 die ganze Zeit connected ist ...
    "Adding an external USB 2.0 device to either ASUS notebook does result in an additional drop in battery life, but the initial damage is done by the integrated camera that you can't unplug. To truly isolate this problem, we'll need two notebooks that don't have any integrated USB 2.0 devices, which is why we turned to the Lenovo Thinkpad T43 and T60."
    Quelle: anandtech.com
    P.S: Es geht mur um USB 2.0 nicht um USB 1.0/1.1 Geräte. (aber natürlich auch um den Ruhestand)
    Ausserdem sieht man das es auch bei Sonoma Plattform was bringt und nicht nur an der Napa Plattform:
    So far, it is looking like this is not a Core Duo problem and indeed a problem that affects all Intel systems at least.
    Zu guter letzt: Microsoft ist ne Blödbacke
    Wollts hier nur mal extra posten ,weil es sonst untergeht.
    Ihr könnt es mal testen,have fun.
    €dit: Es kann sein das man ne Batch Datei schreiben muss (bis windows das hotfix herausbringt),weil laut cb (anadtech hab ich nur überflogen) das Notebook wieder Saft zieht sobald man aus dem standby wieder usb 2.0 Geräte anschliesst. Soll anscheinend nur ein Restart helfen.
    Geändert von dröfl (15.02.06 um 14:44 Uhr)
    Wolfdale 8600 @ 4Ghz 1,33Volt 500Mhz fsb , Gigabyte P35 S3 Rev 1.0 , 6Gb DDR 2 Adata 1000Mhz Ram 5-5-5, old 8800 GTS 600/1400/900
  2. #2
    Oberleutnant zur See Avatar von Magnat84
    Registriert seit
    09.01.2005
    Standard
    Es funktioniert macht es...
    Hab bei mir jedoch noch die Kamera im Gerätemanager deaktiviert...
    Phenomx4955BE@4,0 8GB Asrock880Gpro3 Seasonic380W 8800GT512MB@710
  3. #3
    Oberleutnant zur See Avatar von sphilli
    Registriert seit
    22.06.2005
    im Überwachungsstaat
    Standard
    guter tipp, mal sehen ob es was bringt..
    Desktop: AM2 2,8Ghz -nv570 -HD3870 512MB -4096MB -2x400GB +750GB -WIN7 x64
    Notebook Quanta KN1: -Win7 Grafikkarte defekt
     MacBook Pro 13" -OSX
    Oldscwl Kiste: 1Ghz Kupfermine -440BX Master -4200TI 64MB -512MB -80GB@ ATA66 Promise -XP32
    Agp: 460MX-> 4200ti-> 9500pro-> 9800pro-> 6800 GT-> x1950pro-> Pcie: 6600go-> 7600 go, HD2900pro -> HD3870
  4. #4
    Gefreiter
    Registriert seit
    30.10.2005
    Standard
    Bevor ich in meiner Registry rumbohre...worum geht es und was tut diese Änderung genau?
  5. #5
    Kapitän zur See Avatar von buyman
    Registriert seit
    07.01.2005
    Salzburg (Österreich)
    Standard
    es geht um das problem mit der akkulaufzeit wenn man ein usb gerät angeschlossen hat und die registry änderung behebt dieses problem anscheinend
    Wer die Freiheit aufgibt, um Sicherheit zu gewinnen, der wird am Ende beides verlieren.
    Benjamin Franklin
    Früher im Sandkasten war das alles viel einfacher:
    Da gabs was mit der Schüppe auf die Fresse ... und gut wars - aber Heute?
  6. #6
    Admiral Avatar von subnote
    Registriert seit
    13.06.2005
    Standard
    Fein, muss man ja direkt mal testen
    "Objection, your Honor. You can't preface your second point with 'first of all'." (Alan Shore, Boston Legal)
    [V] Cisco Router, Kabel, Lehrbücher
  7. #7
    Gefreiter
    Registriert seit
    30.10.2005
    Standard
    Das hab ich mitgekriegt
    Nur, bin als Sonoma User betroffen oder nicht? Und was genau tut dieser Fix?
  8. #8
    Registriert seit
    13.06.2005
    Standard
    Einfach mal den ersten Beitrag lesen
Berechtigungen
  • Neue Themen erstellen: Nein
  • Themen beantworten: Nein
  • Anhänge hochladen: Nein
  • Beiträge bearbeiten: Nein
